Govenor drive belts
Govenor drive belts
Home › Forums › General Questions › Govenor drive belts
  • #483072
    Tony Martyr
      @tonymartyr14488
      On a beam engine I built some years ago the watts govenor was driven through a coiled spring steel 'belt' that was bought as a length, cut to suit and jioned by screwing the tapered end into the cut end. I have no idea where I got this material from – can someone point me in the right direction?
      I am a bit concerned that such a drive using vee-groved pulleys might not be able to drive the Double tangye arrangement I have made and have seen in photos that a flat belt has been used – scarf-jointed and glued?
      Tony
      #27488
      Tony Martyr
        @tonymartyr14488
        #483076
          Stuarts do it in about 3mm dia and Mamod spring belts are about 1.5mm dia
          #483078
          Nick Clarke 3
            @nickclarke3
            It used to be a standard item used for film projectors in the 1960's but as they have gone so I suspect has the spring belting from that source.
            #483127
            not done it yet
              @notdoneityet
              Have nothing to suggest except ask if these are the same as, or similar to, the springs use in oil seals?
              #483139
              R Johns 1
                @rjohns1
                Mamod do closed and open ended steel spring belts.
                #483252
                Tony Martyr
                  @tonymartyr14488
                  Thanks to all – I have now found what I needed from Mamod spares
