Fiber change gears
Fiber change gears
Home › Forums › Manual machine tools › Fiber change gears
  • #13981
    Lee Reynolds 1
      @leereynolds1
      #486197
      Lee Reynolds 1
        @leereynolds1
        Hi,
        When I get it up and running I will have a change gear set on my Harrison M300 that will comprise a combination of metal, fiber and Delrin gears.
        Do I lubricate the set, and if I do, what do you more experienced machinists suggest I use.
        I seem to remember reading somewhere that nylon should not be lubricated, is Delrin the same?
        Lee
        #486210
        Anonymous
          My M300 has the original steel and Tufnol change gears. I give them an occasional squirt with ISO68 slideway oil as per the manual.
          #486216
          Ronald Morrison
            @ronaldmorrison29248
            Delrin should not need lubrication buy shouldn't be harmed by lubrication either.
            #486227
            Circlip
              @circlip
              Nylon absorbs water and even the "Low" absobtion rated Nylon 6 or 6-6 does to a lesser extent. Tufnol should not be lubricated, it's a layered material.
              Regards Ian.
              #486237
              Swarf, Mostly!
                @swarfmostly
                Posted by Circlip on 17/07/2020 11:41:31:
                Regards Ian.
                Hi there, Ian,
                Are you suggesting possible delamination?
                Best regards,
                Swarf, Mostly!
                #486238
                not done it yet
                  @notdoneityet
                  Posted by Andrew Johnston on 17/07/2020 10:56:08:
                  Exactly this. As per page 8 of the user manual. Or rather ‘daily’, perhaps?
                  #486239
                  john halfpenny
                    @johnhalfpenny52803
                    Henry Ford used layered tufnol for camshaft gears on millions of cars. Later he used macerated tufnol, and later still a type of nylon. No problems from engine oil.
                    #486246
                    Nick Wheeler
                      @nickwheeler
                      Posted by john halfpenny on 17/07/2020 12:08:15:
                      Although the nylon teeth on V6 cam gears are a notorious week point…….
                      #486254
                      Lee Reynolds 1
                        @leereynolds1
                        Sorry Gentlemen it,s the fiber gear I am more concerned about. It came from 600 group as it was an original gear but missing from my S/H machine.
                        For the price I expected a metal one….silly me! and then the lubrication advice in the manual would make sense and be followed.
                        Lee
                        #486257
                          dont know
                          Certain grades of Tufnol are used for propeller shaft bearings … totally immersed in, and lubricated by, water.
                          A little light reading: http://ahistoryoftufnol.org/whatistufnol/
                          and … https://www.tufnol.com/technical/technical_materials.aspx
                          Edited By Michael Gilligan on 17/07/2020 13:30:35
