ER Collet chuck for Myford ML7R
Home › Forums › Workshop Tools and Tooling › ER Collet chuck for Myford ML7R
  • #485683
    Mark B
      @markb43031
      A while back I purchased an ER25 collet chuck for my Myford – the single piece type which screws onto the headstock spindle. The runout was terrible at > 0.05mm so I returned it.
      I have an MT2 / ER25 chuck but this has the disadvantage of not being able to hold long stock going through the headstock,
      I used to own a Chinese Mini Lathe and that was fitted with an ER25 collet chuck and it was really accurate with <0.01mm runout.
      I really want a good ER25 collet chuck which I can screw onto the headstock spindle and was wondering if this option from RDG would be a good option: Chuck link
      If I machined the backplate carefully would I achieve a repeatable low runout, or are my expectations for this mounting too high?
      Thanks
      #19862
      Mark B
        @markb43031
        #485696
        Sandgrounder
          @sandgrounder
          A few months ago I bought a 2 piece ER32 collet chuck assembly from Myford Ltd and it's excellent, strangely though I can't find it on the website now but they do have the same type in your required size.
          'ER25 Collet nose adaptor assembly 20/294' , sorry about the link I don't know how to post short ones.
          https://www.myford.co.uk/cgi-bin/sh000002.pl?WD=collet%20chuck%20er25&PN=ER25%2dCOLLET%2dNOSE%2dADAPTOR%2dASSEMBLY%2d%2dSMALL%2dBORE%2d%2d20%2d294%2d1433%2ehtml#SID=156
          Myford and RDG are owned by the same company but have different suppliers.
          Edited By Sandgrounder on 15/07/2020 06:52:58
          #485697
          Micky T
            @mickyt
            Hi Mark I purchased an ER32 collet check from RDG for a Grayson Lathe which has an identical spindle nose to the Myford and that was very accurate. I have since machined a back plate for a Boxford which I have attached the ER32 Collet chuck to and that is also very accurate. So in answer to your question yes you can machine a new backplate.
            MickyT
