Dore-Westbury mills
Dore-Westbury mills
Home › Forums › Manual machine tools › Dore-Westbury mills
  • #542609
    DMB
      @dmb
      Anyone know the "usual" power size of motor to drive one of these? Did the MK2 get a more powerful motor?
      Any advice much appreciated, thanks.
      DMB
        @dmb
        #542620
        John Billard 1
          @johnbillard1
          Assuming single phase 220/240v a 500w motor will be fine. I have Mk 1 but I believe the Mk2 is no different in this respect.
          Kind regards
          JB
          #542639
          DMB
            @dmb
            Hi John, thanks. I have just acquired my late friend's MK1 and it has a 1/4hp motor, which I thought was far too small. Seems like I am correct.
            Andrew Moyes 1
              @andrewmoyes1
              I looked up the construction notes supplied with the Mk1 machine. Arnold Throp said 'A 1/3hp motor is quite adequate for all the work a machine of this kind will normally be expected to do.'
              Edited By Andrew Moyes 1 on 01/05/2021 22:52:00
              #542680
              DMB
                @dmb
                Hello Andrew, just found your reply, thanks for that.
                J Hancock
                  @jhancock95746
                  The DW is not the most rigid of machines, 1/4hp will keep you within its limitations.
                  #542703
                  Brian Wood
                    @brianwood45127
                    DMB,
                    When I built my Mk II, I fitted a 1/2 HP motor to it without thinking about the power requirement. The motor itself was a farm sale rescue that had a broken foot mounting but was otherwise a first rate Brook Crompton with ball bearings rather than oilite bushes. Because of the damage the motor was unused and cost me £2
                    From the experience I have had in nearly 30 years of use, I would consider anything less powerful would rather hold the machine back in its capabilities
                    Regards Brian.
                    Edited By Brian Wood on 02/05/2021 10:20:34
                    #542745
                    DMB
                      @dmb
                      Hello John and Brian, thank you both for your replies today.
