Distance between 71/4″ Tracks
Home › Forums › General Questions › Distance between 71/4″ Tracks
  • #123693
    S.D.L.
      @s-d-l
      Anyone have practical experiance of the distance required between parallel tracks running in opposite directions.
      Will need to be more than scale due to passanger trolley widths.
      Steve
      #22694
      S.D.L.
        @s-d-l
        #123705
        Eric Cox
          @ericcox50497
          From a safety point of view they probably need to be far enough apart so passing passengers can't touch with outstretched arms. Your probably looking at a minimum distance of six feet.
          #123725
          S.D.L.
            @s-d-l
            Posted by Eric Cox on 03/07/2013 08:42:32:
            That sounds a good startin point will have a set out with some string.
            Thanks
            Steve
            #123731
            Sub Mandrel
              @submandrel
              Hi Steve,
              I was going be clever and say "the clue's in the 7 1/4" bit" but I see it's a serious question!
              I'm sure I've seen them closer than 6'.
              jason udall
                @jasonudall57142
                The above 6’would assume sane (non suicidal) passengers….was going to say this gap only needed at passing points…but am sure you know that…hse might not..
                #123771
                61962
                  @61962
                  Steve,
                  The HSE did publish a guide a few years ago and the recommended minimum distance between tracks used for public passenger carrying is stated as 2m, although from memory it's not clear whether that's between running edges or centres.
                  I know of one railway that has it's tracks closer than 2m and they close one line if they are passenger hauling.
                  Eddie
                  Edited By 61962 on 03/07/2013 22:43:04
                  #123794
                  Eric Cox
                    @ericcox50497
                    "I know of one railway that has it's tracks closer than 2m and they close one line if they are passenger hauling."
                    Makes you wonder why they had two tracks.
                    #123932
                    61962
                      @61962
                      Because they built it before the HSE put in their two penneth.
