Cutting digital readout scales
Home › Forums › General Questions › Cutting digital readout scales
  • #104323
    Terryd
      @terryd72465
      H Folks,
      I need to shorten a vertical digital scale – i.e. digital readout bar, Can anyone suggest the best way of cutting it and what must I avoid doing to prevent damage.
      Thanks in advance
      Terry
      #22336
      Terryd
        @terryd72465
        #104326
        John Stevenson 1
          @johnstevenson1
          Wrap it with masking tape and slice it with a slitting wheel on the dremel or one of those thin 1mm cutting wheels.
          #104329
          Les Jones 1
            @lesjones1
            Hi Terry,
            Have a look at the thread "Digital Read Out" Do not allow the bar to get too hot as it will damage the printed circuit which is fixed to the bar. I have not seen the 1 mm thick disks that John suggests but this is a source of some quite thin ones if you have a way to mount them. (They are designed to fit an air powered cut off tool.)
            Les.
            #104332
            I.M. OUTAHERE
              @i-m-outahere
              I cut two of mine with a hacksaw and had 0 problems .
              I would probably be worried about static build up using a grinder .
              Ian
              Edited By SLOTDRILLER on 21/11/2012 23:52:10
              #104333
              _Paul_
                @_paul_
                Posted by John Stevenson on 21/11/2012 21:51:33:
                +1
                These things are rather hard IMHO the Dremel makes a clean job of it.
                #104340
                mark mc
                  @markmc72333
                  When i had them i cut mine with a 6x4bandsaw, did a fine job. Not sure about the dremel tho, those disks can build up a far bit of heat the speeds they run at.
                  #104344
                  Les Jones 1
                    @lesjones1
                    Static would not be a problem as there are no electronic components on the PCB attached to the bar. Heat would be less of a problem using a Dremel than an angle grinder but care would still be required. I think the Dremel would give the cleanest cut. Using a saw could possibly tear the tracks on the end of the PCB causing them to short but this could easily be fixed with a sharp knife.
                    Les.
                    #104393
                    Sub Mandrel
                      @submandrel
                      I feel embarrased to admit I cut mine with a hacksaw.
                      I.M. OUTAHERE
                        @i-m-outahere
                        Why Neil ?
                        Isn't that what Hacksaws are for ?
                        Never been one for re – inventing the wheel as those i have seen always seem round enough for me !
                        Hacksaw did the job and the reader head is no where near the cut anyhow .
                        Give it a clean up with a fine file and fit it .
                        The static build up will not hurt the bar as stated there is no electronic components on it but could it jump to the reader head which has CMOS components ?
                        Probably a long shot but if you have luck like mine it will happen sooner or later !
                        More important than cutting is getting the mounting set up right and you will find the pressed metal brackets supplied to be lacking .
                        Make some from square alluminium bar stock on the mill and it will help .
                        Once you have Digitized you will never go back !
                        Ian .
                        #104435
                        Sub Mandrel
                          @submandrel
                          Not mentioned so far are drive brackets for the head! I used 20 gauge brass, flexible enough to take minor misalignment but the plate shape stops any twist that could give a false reading.
