Colchester student thread feed issue
Home › Forums › Manual machine tools › Colchester student thread feed issue
  • #480909
    Ben Cramp
      @bencramp32116
      Hello. I am hoping one of you knowledgeable chaps can help me with my mk2 square head Colchester student lathe.
      The issue is with setting the gearbox for thread feed rate. The lever that controls the E and F ratio doesn't seem to engage. I think it is stuck at the E setting. I can rotate it the near approx 320deg towards F but it seems to meet resistance just before engaging F. Is anyone familiar with this issue or can shed light on what I should look for?
      Its a machine very dear to my heart as it was inherited from my late father so i am keen to get it in full working order.
      Many thanks for any help you can provide.
      Ben
      #13939
      Ben Cramp
        @bencramp32116
        #480948
        Martin Connelly
          @martinconnelly55370
          You may be doing this already, if so sorry for suggesting it. Rotate the gears by hand as you try to select the gears. Try turning the chuck with one hand when selecting gears with the other.
          Martin C
          #480950
          Ben Cramp
            @bencramp32116
            Posted by Martin Connelly on 19/06/2020 18:55:03:
            Martin C
            Hi Martin. Don't be sorry at all. I welcome any suggestions. I'm an amateur machinist so no idea what i'm doing half the time. But yes, have tried that with no luck unfortunately.
            #482130
            Ben Cramp
              @bencramp32116
              Little update. All fixed. The leadscrew gear had been chewed up by a dissengaged sliding brushing. Found a replacement gear and now working perfectly
              #482361
              Howard Lewis
                @howardlewis46836
                Thanks for telling us the end result.
                Glad to know that you are up and running again!
