Cleaning hands.
Cleaning hands.
Home › Forums › General Questions › Cleaning hands.
Viewing 25 posts - 1 through 25 (of 36 total)
  • #22696
    Chris123
      @chris123
      #123826
      Chris123
        @chris123
        Just interested in how people clean their hands when given the five minute countdown for dinner?
        I use Swarfega barrier cream then Swarfega (the orange one with bits in) soap.
        #123827
          Same Orange Swarfega here
          #123828
          martin perman 1
            @martinperman1
            Gentlemen,
            I use Swarfega orange but I have another method of getting hands spotless, my job means that I have to wear protective clothing etc and this also means I have to wear thin rubber gloves and I found that if I had been restoring one of my Lister engines and got covered in oil, grease etc and had to wear gloves at work the next day the sweating action would clean them spotless. I dont wear them at home as I find them getting in the way but at work I have no choice.
            Martin P
            #123829
            Steve Purves
              @stevepurves30189
              #123830
              Robbo
                @robbo
                Green Swarfega mixed with liquid soap. The soap does away with the Swarfega pong!
                #123831
                Gray62
                  @gray62
                  Wife hates the smell of Swarfega, I use Manista which meets with her approval
                  #123836
                  Mike Clarke
                    @mikeclarke87958
                    Washing up liquid and sugar.
                    #123838
                    John Baguley
                      @johnbaguley78655
                      Swarfega Orange. The green stuff was/is awful!
                      #123839
                      Stovepipe
                        @stovepipe
                        Daz washing powder or similar. Used it 50 years ago in the workshop.
                        Dennis
                        #123849
                        GaryM
                          @garym
                          While we're talking about Swarfega, I've had a tub in the kitchen cupboard for years (forget to use it) which has now turned to liquid. Any ideas why and if I can return it to its semi-solid state.
                          Gary
                          #123850
                          John Stevenson 1
                            @johnstevenson1
                            Throw a handfull of sawdust in it, that's usually what the bits are in hand cleaner.
                            #123852
                            Gordon A
                              @gordona
                              Liquid hand soap and sugar. (A bit kinder on the skin than washing up liquid despite what the adverts claim!)
                              Gordon.
                              #123853
                              Falco
                                @falco
                                I have never liked Swarfega, nor found it much good. Same goes for a lot of the cleaners on the market.
                                Lidl do a W5 heavy duty hand cleaner in a round tin that I find exceptionally good. A small amount does a very thorough clean. Feels very soapy when washing off. Rinse till the soapy feel goes and hands are spotless. Not at all severe on the hands and leaves skin soft . I wouldnt buy anything else now.
                                They only have it in occasionally and all the local motorheads have got to know it so it walks off the shelves on the days it is on offer. Worth a try.
                                #123854
                                steamdave
                                  @steamdave
                                  Before starting to get my hands dirty in the workshop, I rub in some barrier cream. It really does prevent getting your hands too hard to clean afterwards. Most of the time I could get away with using soap and water, but just to make sure, I usually clean off with De-Solv It beaded hand cleaner before the soap. It is petroleum free so doesn't take all the oil out of your skin. Got it off eBay, but I think Kleenezee or one of those type of outfits sell it.
                                  The Emerald Isle
                                  #123856
                                  Thor 🇳🇴
                                    @thor
                                    Like Martin I usually wear gloves when working in the workshop, so oridnary liquid hand soap is enough to get my hands clean.
                                    Thor
                                    #123857
                                    Hopper
                                      @hopper
                                      WD40 then a sloosh in a bucket of water and dishwashing soap that I keep in the shed.
                                      #123865
                                      I.M. OUTAHERE
                                        @i-m-outahere
                                        Simple !
                                        Don't get them dirty !
                                        I had a boss a few years ago at a hardchrome place that got some chromic acid on his hands so he went to the caustic strip tank and dunked his hands in , he didin't know i had dumped a 100 kg of caustic crystals in there the day before !
                                        By the time he got to the tap he was screaming !
                                        All he was worried about was the stain from the chromic acid but losing several layers of skin solved this !
                                        The only stuff i have found that will get the smell of diff oil off you is washing powder and yes i have had to have a shower using this – some one told me they had drained the gearbox oil but when the tailshaft was unplugged from the rear of the gearbox i discovered they had not !
                                        I now mostly use diswashing liquid but if really dirty i use hand cleaner and here in Australia i found that the products from HI TEC to be best , i have used just about every product available here over 30 years and as usual no connection just a satisfied user .
                                        There is a smell to diff oil and kidneys that nothing will kill even vinigar so these days if i do work on a gearbox i wear gloves and if i make steak and kidney pie i wear gloves!
                                        Ian
                                        #123877
                                        Lambton
                                          @lambton
                                          Lidl's W5 heavy duty hand cleaner is excellent. It removes all sorts of muck from the hands including some that Swarfega will not even "look at" such as paint, hardened Isopon etc. . After I have got the muck off with the W5 I then use ordinary soap and water to finish the job so that I can be allowed into the house again!
                                          #123882
                                          Gordon W
                                            @gordonw
                                            Green swarfega for heavy dirt (old oil etc.) washing up liquid for normal muck. Wash hair to deep clean hands. Had a mate, a motor mechanic , who reckoned eating fish and chips was the best hand cleaner.
                                            #123890
                                            oilcan
                                              @oilcan
                                              I always try to wear nitrile disposable gloves in the workshop. Not perfect, they do tear, but with the use of talcum powder to put them on I can get a few uses out of one pair. If you do go this route, don't try to save money by getting latex ones. The first time you turn the cross slide handle they'll just wind themselves around it.
                                              #123906
                                              Sub Mandrel
                                                @submandrel
                                                Washing up liquid and sugar, usually. Bought some green swarfega (the most evocative smell from my childhood!) but my wife appropriated it for my stepson
                                                The real tip is to use lanolin barrier cream then you can clean up with soap!
                                                Lambton
                                                  @lambton
                                                  I have never understood the very common notion that sugar added to soap of washing up liquid etc. has any beneficial effect in cleaning hand. Perhaps it is the initial gritty feel of the sugar granules that give the impression that it is a good cleansing agent. Sugar is readily soluble in warm water and as far as I know has no solvent action on oil and grease.
                                                  No doubt someone may be able to explain the reason why sugar is used in this way.
                                                  Eric
                                                  #123918
                                                  Sub Mandrel
                                                    @submandrel
                                                    Hi Eric,
                                                    Soap doesn't dissolve in the WUL and so acts as a gentle abrasive. The Washing up liquid acts as a craiier. It then dissolves when you add water and the detergent can go to work. It's like the granules in fast orange or similar.
                                                    You could use sand, but of course it would be harder to was away at the end, plus sugar and washing up liquid are found in all kitchens.
                                                    Peter G. Shaw
                                                      @peterg-shaw75338
                                                      In days of yore, ie BME, I used to do all my own car maintenance and generally got rather mucky. A quick jam of the old digits into the boss's washing machine powder, a drop or three of H2O and off all the muck came. Then I discovered Swarfega – the green version – which I think is probably better for the hands than detergent powder.
                                                      I find that Swarfega along with a scrubbing brush – as long as it is a decent stiff one, and not a namby-pamby ladies gentle skin tickler one – does the job satisfactorily.
                                                      Recently, Aldi had a pack of disposable latex gloves going remarkably cheap. Perhaps as well because it would be remarkably easy to damage three or four a day. I've now, after only a few days gone back to bare hands.
                                                      I did find with these gloves that they became extremely slippery once they came into contact with cutting fluid or oil. Ok, it wiped off easily, but in the end, I'm not convinced.
                                                      I've also used paraffin to get the really deeply engrained stuff off, WD40 if it happens to sticky stuff or methylated spirit for Araldite, and sometimes white spirit/turpentine for paint. I've even used that horrible solvent for Hammerite paints. But, these days I do wonder just what damage these items are doing to the skin so I can't really recommend any of them. Of course, after using these liquids I usually have a good handwash with good old soap and water. Perhaps the answer may be to reserve the gloves for use with the worst of these solvents.
                                                      Peter G. Shaw
                                                      (BME – Before Model Engineering)
