Caterham tacho – possible use to show RPM
Home › Forums › The Tea Room › Caterham tacho – possible use to show RPM
  • #507647
    Frances IoM
      @francesiom58905
      One of the many items acquired at auction sale for little outlay was Caterham tacho – EET3-1A32-00B marked as 0-8000 rrm (dial just 0-80) 4cyl – it as a strange to me 6 pin connector – I can find no info as to how to drive it – my idea is to use a cheap arduino to interface – can anyone advise – it looks undamaged and case is marked ok but I have no guarantee it still works sorry title should be RPM of my mill
      Edited By Frances IoM on 15/11/2020 14:46:38
      Fixed the title typo for you! Dave
      Edited By SillyOldDuffer on 15/11/2020 14:54:42
      #36152
      Frances IoM
        @francesiom58905
        #507653
          I would start by looking here: **LINK**
          https://www.lotus7.club/forum/techtalk/random-rev-counter
          and continue by wondering if it’s worth more to them than you could buy an alternative for.
          Frances IoM
            @francesiom58905
            can’t see any help there, could you please point out anything I missed – what I need is the pin-out (+ possibly a reference to the connector tho I guess I could work thru the many hundred RS sell) as well as possibly the functions of the 6 dip switches accessible from the rear – I doubt if it is worth much but having a brother who has a Lotus I’m aware of the cost of repairs. It is just an attractive instrument 80mm diameter
            #507660
            Pete Rimmer
              @peterimmer30576
              If it says 4 cyl on it then it's probably an electronic one triggered by the coil low tension side or even an inductive pickup. When you buy after-market ones they usually have a selector switch to set the number of cylinders so that it reads true, because different number of cylinders usually means different number of pulses per rpm.
              #507710
                Posted by Frances IoM on 15/11/2020 15:49:11:
                can't see any help there, could you please point out anything I missed –
                Sorry to have wasted your time … I presumed that, as they were discussing the existence of two different pin-outs, it might be worth contacting them.
                Steviegtr
                  @steviegtr
                  Posted by Michael Gilligan on 15/11/2020 20:15:19:
                  Ditto, i would have thought that to be the perfect place to get info.
                  #507723
                  Maurice Taylor
                    @mauricetaylor82093
                    Hi, this might be useful. **LINK**
                    Maurice
                    #507726
                    Maurice Taylor
                      @mauricetaylor82093
                      Posted by Michael Gilligan on 15/11/2020 15:15:37:
                      Hi ,this link gives you the name of the maker .Put name in google ,to find website ,this has instructions for gauges .
                      I think you might be able to drive it direct from a Hall sensor
                      Maurice
                      Edited By Maurice Taylor on 15/11/2020 21:51:20
                      #507728
                      Jon Lawes
                        @jonlawes51698
                        I'd be tempted to sell it and use the money to buy something more fit for purpose.
                        #507741
                        Frances IoM
                          @francesiom58905
                          I could easily just use a 4digit display as a purely functional display but I fancied something different – I have no idea if it actually works as I took a punt on it,for I think 1 or 2 pounds, at the local auction where sometimes I have struck lucky in that no-one had recognised a specialised tool or item – tho I usually avoid items I can’t physically handle and inspect, I have been tempted and often get a dud where an obvious non-working device has been repackaged to appear new – eg in one case I bought an extractor fan in original packaging only to discover that the fan blade behind the grill was absent – deceptive sales are not restricted to Ebay but at auction houses there is seldom any come back – caveat emptor strictly applies.
                          I had discovered previously the same thread but was confused by mention of lights as mine appears to have no visible indicators – catch is I cannot extract it from the case – the front bezel once a rubber seal in moved can be twisted but doesn’t want to come away from the ‘can’ protecting the mechanism
                          #507743
                          Maurice Taylor
                            @mauricetaylor82093
                            Posted by Frances IoM on 15/11/2020 23:13:49:
                            I had discovered previously the same thread but was confused by mention of lights as mine appears to have no visible indicators – catch is I cannot extract it from the case – the front bezel once a rubber seal in moved can be twisted but doesn't want to come away from the 'can' protecting the mechanism
                            Hi ,Have you had a look at makers website and downloaded instructions ? Why do you need to get it out of case,connections and switches should be on back.
                            Maurice
