Carbide Cutters
Carbide Cutters
Home › Forums › General Questions › Carbide Cutters
  • #22706
    Alan .204
      @alan-204
      #124247
      Alan .204
        @alan-204
        Hi chaps any one know where I can buy some carbide tips I'm after the solid type not the ones you hold one with a small bolt, I will silver solder them on to home made holders.
        Thanks Alan.
        #124265
        Thor 🇳🇴
          @thor
          Hi Alan,
          if you can use triangular (uncoated) inserts you can try RDG. I have silver soldered worn (uncoated) triangular inserts onto homemade holders. Just grind and hone before use.
          Here's another carbide supplier.
          Thor
          #124402
          Ian S C
            @iansc
            Or heres a way of mounting that works quite well, this tool holder is getting fairly worn after twenty years of use. Ian S C021 (640x480).jpg
