Posted by Bandersnatch on 18/07/2015 17:21:48:
Posted by Russell Eberhardt on 18/07/2015 14:06:27:
If you're going to do a lot of work with brass it's worth keeping a set of modified drills specially for brass.
+1
-2 if it's going to be bored why bother. Drilled smoothly a clean hole will be produced. If the drill grabs don't let it.
One of my first lathe purchases was a set of blacksmith drills. Loads on ebay. They allow holes to be drilled up to 1in or 25mm in stages and all have 1/2in shanks. Mine are the black ones.
Sometimes it's difficult to get a hefty boring bar on a lathe say 16mm dia. My Boxford has a Myford branded qctp. What they did to get the additional tool height was to add a plate to the bottom and use the same 1/2" holders. It's fairly easy to make a separate holder for a larger bar. Block of steel and T bolt to fix it in the usual slot. Drill through it to suit the diameter of the bar and add clamping screws. If you might want to get these screws out after much use make sure they are high tensile ones and just to be sure chamfer the ends a little.
The hole for the boring bar needs to pass close to the fixing hole to help reduce twisting moments. The base of the block area shouldn't be too much smaller than the normal tool post really and do make sure the bottom is flat and well finished. If block turned in a lathe it will be concave so lap it. They can be made out of round bar too.
The cutting edge of some of the indexed boring bars is on the centre line of the bar or better still for boring a few thou above it. In this case the hole for the bar can be formed with a drill from the headstock but it would be best to ream it as well.
Super fancy ones can be made as well. with several hole sizes.
Maybe a bit over the top in this case but twisting moment on the holder is very low as the bar passes though the fixing's centre.
