best grinder for hss
Home › Forums › Workshop Tools and Tooling › best grinder for hss
  • #191302
    mick70
      @mick70
      want to get grinder just for hss tooling rather than using my normal bench grinder.
      any recommendations for a good one pls?
      #17722
      mick70
        @mick70
        #191363
        JohnF
          @johnf59703
          Why do you want something other than your bench grinder ? What tools do you intend to grind if it's lathe tools you really don't need anything different unless you intend to go the whole Hogg and use a tool & cutter grinder.
          A bit more info regarding your intentions or aspirations might help.
          #191384
          mick70
            @mick70
            sorry should have been clearer what i mean't was do i need special type of wheel?
            like for my tig tips i have green wheels on mini grinder specificaly for that job.
            will be getting seperate grinder as want to keep just for lathe tooling.
            #191385
            Nick_G
              @nick_g
              I have one of these. No complaints so far. **LINK**
              Not the best tool rests. But then it's not in the price bracket of one that does. I tell myself I may someday make some.
              Nick
              Edited By Nick_G on 27/05/2015 15:08:15
              #191393
              Vic
                @vic
                I sharpen most of my HSS tooling on a belt sander.
                #191415
                Robbo
                  @robbo
                  John,
                  Editing is permitted, but only for a limited period after the post has been 'posted' You can even leave the site and as long as you return quite soon there will still be an 'edit post' icon to click on.
                  Edit; the 'edit post' appears in the green header bar after the date.
                  Phil
                  Edited By Robbo on 27/05/2015 19:29:58
                  #191418
                    Mostly I rough out on a grit wheel and put on a quick polish with a diamond wheel.
