balata flat belt
balata flat belt
Home › Forums › Workshop Tools and Tooling › balata flat belt
  • #190450
    Black Cat2
      @blackcat256889
      Having just bought a Pools lathe with a flat beltpulley I cannot find 3/4 inch wide balata..
      Not had experience of flat belting so I wonder if I can use 1inch anyway if its lined up well or can I cut astrip off it .? Will it fray and turn to dust before I can turn something?!
      #17715
      Black Cat2
        @blackcat256889
        width
        #190514
        Tim Stevens
          @timstevens64731
          Try a multi-V belt as used for car alternators etc, and use it inside out.
          Tim
          #190520
          Brian Oldford
            @brianoldford70365
            Are there any multi-V/poly-V belt experts here?
            #190522
            Black Cat2
              @blackcat256889
              There will be soon!
              I ll try it..
              Thanks Tim
              #190527
              bodge
                @bodge
                HI been there and done it already ! It works, no need to turn inside out . The suppliers usually charge by the rib ,about 8 ribs for 3/4 inch wide .
                Bodge
                #190530
                Johan van Zanten
                  @johanvanzanten
                  I used a timing belt from my car inside out for years. Works fine!
                  #190534
                  Black Cat2
                    @blackcat256889
                    Well thats sorted!
                    Now I dont have anything to use it on!
                    Buying things unseen has always too much luck involved but having seen this little Pools lathe with a repaired crack in the headstock for not much money I took the risk..Only wanted it for screwcutting anyway..
                    On receiving it I found there is a little play in thehead bearing,I m sure that can be adjusted, but also the saddle wont go forward..Its sounds like the thrwad is slippng..Shame as its good in all other respects so its going cheap on the classifieds ..I m going to buy an Ama cj18 and hope the gears dont pack up too soon..
                    There is one thing though..With the Pools came an original all steeltreadle in excellant condition which I m keeping..So the belt info isnt wasted!! Thanks everyone..
                    #190536
                    Black Cat2
                      @blackcat256889
                      Ha ha! Amadeal cj18 gone up ?50 overnight!
                      Now does anyone know if SPG lathes are equivalent please? They are still quite a bit less and I could collect it..
                      What a palavar for a bit of screwcutting!
