Posted by Brian John on 16/07/2016 11:13:49:
Are brake hone grit sizes quite different to sandpaper grit sizes ? 220 grit would be very rough sandpaper and I can't imagine polishing the inside of a brake cylinder with it.
It is not meant to polish the bore, as the name implies i is used to HONE the bore where a very fine cross hatch of fine scratches are desirable.
Finer than that would be lapping and then polishing.
The one you link to is ideal for honing model cylinders wher an iron piston ring will be used
