Apex taps
Apex taps
Home Forums General Questions Apex taps
  • #493655
    Axel Bentell
      @axelbentell
      I bought bunch of taps from Reeves2000 two years ago. I do not know if this is their own brand, but they are called Apex. Worst rubbish I have ever come across!T he smaller ones break all the time, even in soft BMS and soft finger pressure. Are there any ME thread taps available from a quality brand?
      #27609
      Axel Bentell
        @axelbentell
        #493661
        Circlip
          @circlip
          Try Tracy, good selection.
          Regards Ian.
          #493676
          Baz
            @baz89810
            Tap and Die company, very good quality.
            #493682
            KWIL
              @kwil
              Lubrication, back off to clear flutes, guide block to hold perpendicular??
              #493694
              Brian H
                @brianh50089
                I'd go with the suggestion from Baz. Tap & Die products are OK.
                #493701
                Mike Poole
                  @mikepoole82104
                  Carbon steel taps are rather brittle and do not bend. Tapping small sizes is safer with a tapping fixture like one of the roles of the universal pillar tool, only the slightest side pressure will snap a small tap. I have one or two Apex taps and found them to be ok.
                  #493711
                  not done it yet
                    @notdoneityet
                    First question might be :How are you using them? Tapping size of holes, tapered, second or plug taps, tapping arrangement and cutting compound can all make a difference between success and failure.
                    #493714
                    Chris Evans 6
                      @chrisevans6
                      For most tapping I do especially for small sizes I drill at least 0.1mm oversize. Usually 0.2mm and mostly tap on the mill with a guide to keep vertical. Rocol or similar RTD and a squirt of tapping fluid as well. I haven't broken a tap in the last 15 or 20 years. Edit, all my taps are HSS.
                      Edited By Chris Evans 6 on 01/09/2020 14:28:22
