Here in darkest Australia I have had both a pair of shoes and a pair of workboots ( neither Clark's ) kept for several years unused, one pair in the original cardboard box and one in the airing cupboard, both of which fell apart on first use. The boots fell apart in the garden which was disappointing, the shoes at the optician leaving bits stuck to the floor both on the way in and the way out. Very embarrassing!
Since a good pair of boots should last for quite a few years I would say the sole material is not fir for purpose. The same could be said for the shoes however as these are typically expected to have a shorter lifespan the rapid breakdown of an item which is unlikely to be recycled is perhaps an environment benefit. No, I don't believe it either but I'm sure the shoe companies would push this line if they think of it.
As others have noted it is not something I have encountered with regularly worn shoes. As an example, two pair of shoes bought at the same time, one worn to death with no damage to the sole other than expected wear, the second pair worn the day after with immediate failure of the sole. Perhaps there is someone out there that can explain the chemistry, it's beyond me.
It also makes me query the long term survival of polyurethane insulation materials and adhesives where one would hope for decades of performance – hopefully better chemistry, but I will be more cautious in future use.
Back on the treatment of sticky plastic, one benefit of hand sanitizer is that it usually contains glycerine or similar as a moisturiser which is good for most plastic surfaces in addition to your hands!I have on occasion used talc but have found that over time it just results in a rather dirty sticky surface as the cure is only skin deep and the underlying deterioration continues.
Pero
