240/415 motor
240/415 motor
Home › Forums › General Questions › 240/415 motor
  • #124566
    ron grimshaw
      @rongrimshaw76129
      Hi all
      I have just been given a chop saw from a window frame company that as run on 3 phase the motor is a asincrono 1.5hp it state that its 240/415, does this mean that it can be run on single phase with just some wiring change.
      I have no knowledge in electrics when it comes to motors, Would I need to get a convertor and if so which one and from where.
      Ron
      #22717
      ron grimshaw
        @rongrimshaw76129
        #124568
          Ron,
          No … a three phase motor is always a three phase motor.
          240/415 is to do with Star/Delta connection.
          The good news is that if you wire it for "240" you can drive it from a Static Inverter; which generates three phase from a household single phase input.
          Others on this forum will be able to advise you in much more detail, but I thought I should start the ball rolling.
          ron grimshaw
            @rongrimshaw76129
            Thanks for that quick response
            Ron
