Filing Cast Iron
Filing Cast Iron
Home › Forums › Beginners questions › Filing Cast Iron
  • #9235
    Malcolm Harvey
      @malcolmharvey97633
      #359680
      Malcolm Harvey
        @malcolmharvey97633
        I am not particularly a beginner but I thought I would ask this question here as it is likely something that every beginner should know.
        I have turned a set of wheels for my 3½G Titfield Thunderbolt but I have casting flash between the spokes (of course). I have tried filing this out with swiss files but they clog almost immediately. Does anyone have any suggestion as to what would be the best tool to use for this job?
        TIA
        Malcolm
        #359682
        Weary
          @weary
          Dremel – or similar – with carbide burrs.
          (Plus tight-fitting goggles as abraded cast-iron mini-granules get everywhere!)
          Phil
          #359718
          Jim Nic
            @jimnic
            +1 for a Dremel
            Jim
            #359722
            vintagengineer
              @vintagengineer
              Rub chalk on the file and use a file card to clean the file.
              #359738
              Baz
                @baz89810
                In my very humble opinion a much better way to clean a file is to use a piece of brass or a fine brass wire brush.
                #359739
                roy entwistle
                  @royentwistle24699
                  Baz The chalk is not to clean the file it's to stop clogging. Definitely a bit brass or copper for cleaning
                  Roy
                  #359740
                  Chris Evans 6
                    @chrisevans6
                    What "Cut" is your file ? I use "O" cut for those sort of jobs.
                    #359743
                      For small areas of 'casting flash' I have found that diamond 'needle files' work better than conventional ones.
                      A few years ago, this would have seemed an extravagance; but the availability of [cheap & cheerful] sets from the likes of Aldi and Lidl has changed my approach.
                        Posted by Baz on 28/06/2018 08:35:29:
                        Only really works for single cut files.
                        #359784
                        Malcolm Harvey
                          @malcolmharvey97633
                          Thanks for the input. Learnt a bit! Never heard of putting chalk on a file to stop it clogging, Never have thought of using a Dremel and I hadn't heard of diamond needle files. I have just looked in Boyes and they have pack of 5 for £4 or thereabouts.
                          Malcolm
                          #359792
                          mechman48
                            @mechman48
                            +1 for the Dremel approach. I also use a rough 2nd cut to get under the meat of the flashing then titivate up with Dremel & carbide bit.
                            George.
                            Edited By mechman48 on 28/06/2018 15:21:37
