Myford ML10 Lathe Manual by Ian Bradley wanted
Home Forums Books Myford ML10 Lathe Manual by Ian Bradley wanted
  • #821265
    Stuart McGuigan
      @stuartmcguigan
      Does anyone out there have a copy of the above book – ISBN 9780852425459 – that they would be willing to sell, or lend me to photocopy please?
      Regards to all,
      Stuart
      #821269
      John Haine
        @johnhaine32865
        Where are you located?  There \re several co[pies at various libraries, see
        https://openlibrary.org/books/OL23639366M/Myford_ML10_lathe_manual
        #821295
        Andrew Tinsley
          @andrewtinsley63637
          Frankly, I would not bother. It is not a patch on his excellent ML7 series book. Most disappointing to say the least and copies are quite expensive.
          Andrew.
          #821300
            Stuart McGuigan
              @stuartmcguigan
              Thanks to John & Michael.  I am aware of the maker’s manual and library copies.  However, I would really like my own copy of the Bradley book.
              regards,
              Stuart
              #821346
              Trevor Drabble 1
                @trevordrabble1
                Stuart , myford- lathes are advertising 3 off @£47 ea. At the recent Midlands Exhibition I noticed good stocks of used books on The Engineers Emporium stand as well as a few on Home and Workshop I believe . Maybe worth a couple of phone calls ? Trevor .
                #821501
                Trevor Drabble 1
                  @trevordrabble1
                  Would also suggest you look at the PBFA web site to see if theres a convenient book fair to you . Because of the number of secondhand book sellers attending past fairs , I’ve been able to find a number of books I wanted . Good luck with your search .
                  #821511
                    You would do better using the Wanted classifieds as a post here will disappear off the screen in a day ot two.
                    Also photocopying is not encouraged
                    #821589
                    Stuart McGuigan
                      @stuartmcguigan
                      Thanks for your suggestions Trevor.
                      Stuart
                      #821592
                        Chris Crew
                          @chriscrew66644
                          I agree with Andrew Tinsley. I had an original copy of the book when I owned an ML10 and can confirm its contents were very disappointing, a bit like the ML10 itself, IMO! Far better to acquire a copy of Sparey’s ‘Amateur Lathe’ or anything by GHT or Martin Cleeve and then a half decent Super 7 or at least an ML7R.
                          #821668
                          Trevor Drabble 1
                            @trevordrabble1
                            Stuart , Sent you a PM .
                          Home Forums Books Topics
