Task Light
Task Light
  • #814827
    Vic
      @vic
      My new task light, made from a spare LED torch and a Gooseneck from Amazon. Both ends of the Gooseneck had 1/4” 20 male threads that didn’t look overly durable. I decided to make a couple of stainless steel spigots that screw onto the ends but slip over about 18mm of the main body of the Gooseneck. The spigots are a snug fit providing support. Next I made a clamp for the torch and a couple of thumbscrews from aluminium alloy. The smaller thumbscrew has a plastic thread to help prevent damage to the body of the torch. The top spigot fits into the clamp and the lower into a retort stand base I already had. I may make a magnetic base at some point or make something to fit an existing mag base.
      IMG_5317
      #814856
      noel shelley
        @noelshelley55608
        That’s neat ! An alternative to the plastic thread is a small plug of plastic or a plastic tip on the metal screw to avoid damage to surfaces that you do not wish to mark. Noel.
        #814927
        Vic
          @vic
          Yes, I did think of inserting some plastic into a metal thread, I’ve done this with brass and copper inserts before. I’ve got some M6 plastic number plate screws, so used the thread from one of those. I was torn between, Black, White or Yellow. 😆 I went with White in the end.
          #818864
          andy198712
            @andy198712
            How did you make the knobs? Just plunge a 3mm end mill to get that effect on the rotary table or? Nice
            #818905
            Nigel Graham 2
              @nigelgraham2
              Very neat lamp!
              I have made scalloped fittings like those knobs, in two ways.
              One by end-mill and rotary-table as Andy suggests: I cut radially rather than by plunging.
              The other by drilling a pitch-circle of holes on what would become the final diameter, then turning the rim down to that, thus halving the holes. That was on a lamp bezel, and drilling under-depth gave a neat closure to each scallop, resembling those on the original plastic moulding I was replacing.  (A ball-ended end-mill of course would give a hemispherical rather than hemi-conical run-out. )
              #818920
              Paul Lousick
                @paullousick59116
                I have something similar that I bought from ALDI which has an LED light and a clamp on the end of a flexible support. It has a USB plug on the end of the cable and can run from a mobile phone charger or power bank.
                Light
                #818924
                larry phelan 1
                  @larryphelan1
                  I have three of those Aldi/Lidl type lamps, bought for very little and I find them to be one of the best things I ever bought. I use one on my lathe, another on my mill and the third one between my drill and my laptop, depending on which needs it most.
                  Well worth keeping an eye out for them show up again.
                  #818936
                  Vic
                    @vic
                    I mounted the material in a Spin Indexer and used a Bull Nosed End Mill.
