Thank you Judy. I will see if they would “break” a pack.
Bernard – I have started to have a go at making one and started off by making the “D” shaped taper reamer. I see a problem of making the tapered plug.
Leaving the topside (of my watchmaker’s lathe) set to the same angle as the reamer, I can turn the taper plug, then will either have to set the topside back to zero and turn parallel for the 10Ba thread one end and the square the other end or move over to the Boxford and try to centre it up in the larger chuck. If I choose to set the watch lathe back to zero and bog up the brass plug, I can’t accurately set up the same angle again – Oh dear !
Bob
