connectors for NEMA17 motors
Home Forums General Questions connectors for NEMA17 motors
  • #796787
    Roger Hart
      @rogerhart88496
      Planning building a telescope drive – 2 Nema17 motors off hand held home brew stepper drive box.  Power source 12 volt (Lidl) battery so not a big shock hazard.
      What connectors would be reasonably robust and not cost an arm&leg?  One 4 wire cable to each motor.
      John Haine
        @johnhaine32865
        I generally use XLR connectors:
        https://uk.rs-online.com/web/p/xlr-connectors/0457908?gb=s
        RS probably not cheapest source.
        #796811
        Peter Cook 6
          @petercook6
          I used these when building my rotary table stepper. Cheap, positive screw down ring  & rubber plug for when disconnected.
          #797015
          Roger Hart
            @rogerhart88496
            THanks both for the steer.  Will ponder and check prices.
            #797030
            John Haine
              @johnhaine32865
              If you’re quick, Arc have some 4 way chassis sockets for £1.94 each.
              https://www.arceurotrade.co.uk/Catalogue/Stepper-Motors/Wiring-Accessories/4-Way-XLR-Chassis-Socket
