I've recently bought a Warco mini lathe after having used a Unimat 3 for many years. I ordered a B16-MT2 tang arbor for the tailstock chuck without realising that the tailstock screw will interfere with the tang and the arbor really needs to be hollow – currently the only way to use the chuck is to wind the tailstock about 2 inches out before inserting the chuck, which makes the tailstock screw action almost completely redundant.
So, what sort of arbor should I have ordered? I've seen hollow arbors threaded for a drawbar but that isn't necessary in this case although I guess one might work if the tapped hole is oversize by a large enough amount. I haven't seen anything that looks like it's specifically designed for this purpose – or have I just not been looking hard enough?
Thanks in advance,
Chris
