Myford ML4
Myford ML4
Home › Forums › Beginners questions › Myford ML4
  • #136422
    John Waterfield 1
      @johnwaterfield1
      Hi all. I got a Myford ML4, (or so i think ) i have looked all over it for a serial number but no joy, i can only go by pictures online, if anyone knows where the serial number might be, that would be great. This is the first time i have had a Myford, so my knowledge isvery limited. anyway to get to the point.
      I want to change the headstock pulleys from flat to v-belt, but i don't know if i can use any v-belts system from a different model without having to change or remake the spindle. The spindle it has is the old one with a 7/8 X 12 tpi thread, i could really do with some help on this.
      Many thanks. John
      #6958
      John Waterfield 1
        @johnwaterfield1
        Headstock pulleys
        #136433
          Welcome, John
          If the lathe is already equipped for flat belts, may I suggest that you convert the existing pulleys to PolyVee [or get someone else to modify them for you] … These are much more efficient than simple vee belts and the end result would be very neat.
          You will find several useful threads about PolyVee [various spellings] on this forum.
          Note: It's best to use the Search Box on the homepage, not the one at the top of this thread.
          Brian Wood
            @brianwood45127
            Hello John,
            If I remember correctly, serial numbers for ML4 lathes were stamped onto the lathe bed at the tailstock end onto the unmachined face of one of the shears. It also appeared on the lathe mandrel gear and the two numbers should of course match. I still have a handbook I will scan for you if you can't get a copy from elsewhere.
            I can't help with your pulley change, but I don't think for one moment you need to make or alter the mandrel, it is much easier to make the pulleys to suit. You will of course need access to a lathe to do the work,so you may well need help there. I endorse Michael's comment above on Poly Vee drive, a much better system altogether.
            Brian Wood
            Edited By Brian Wood on 26/11/2013 09:06:26
            #136441
            Robbo
              @robbo
              John,
              You may find it helpful to join the Yahoo Myford Group at **LINK**
              You will find an ML4 manual in the "Files" section.
              Phil
              #136443
              ega
                @ega
                I found only one very short thread which didn't cover the points which came to mind when I saw your suggestion.
                I have no experience of Poly-V apart from those under the bonnet and in the washing machine but did wonder how they stand up to operating in an oily environment. Also, I understand that they should be run considerably tighter than conventional vee belts thus increasing the pull on the spindle.
                #136446
                  Posted by ega on 26/11/2013 10:18:07:
                  Here are the results that I found !!
                  Edited By Michael Gilligan on 26/11/2013 10:54:08
                  #136448
                    … Then it would be worth you reading some of the documentation
                    NJH
                      @njh
                      Hi John
                      My first lathe was a ML4 with a flat belt drive. The belt was, I'm pretty sure, someones old trouser belt, shortened appropriately, with the ends scarfed and stitched together! I had it for some years and never changed the belt. It had one distinct advantage for the beginner – any foul up caused the belt to come off the pulleys thus avoiding disaster! My advice would be to live with the flat belt for a while and only go through the convert to "V" belt when it is causing you real annoyance. The ML4 is, after all, an old lady and deserves to be treated kindly – I had a lot of fun with mine.
                      Good luck
                      Norman
                      #136452
                      ega
                        @ega
                        Many thanks indeed. I will certainly look at your results.
                        For my benefit, what search string did you use? I did take your advice and search from the home page although it is hard to see why this should make any difference.
                        #136459
                        ega
                          @ega
                          NJH
                          I take your point about respect for old machinery. As the ML4 is capable of real work I suppose that it's the balance between its original character and present usability that matters. In this connection, it's interesting to see how Myfords developed their classic lathe; they lost me when they made it impossible to open the change gear cover without a tool.
                          Foul ups: the conventional vee belt slips, of course. I didn't realize that a flat belt would react by coming off the pulley and find this interesting because I understood that it was the tension in the belt that caused it to ride up to the crown of the pulley.
                          #136473
                            Posted by ega on 26/11/2013 11:15:30:
                            ega,
                            I think there must be more than one way of searching from the homepage
                            Edit: and indeed there is !!
                            The one that works is the Google Search box, that's just to right of centre and in amongst the "what's in issue x" boxes
                            David Clark kindly provided this search facility, because the forum one produces such poor results.
                            … It just provides a quick link to Google's.
                            The results I showed are from searching for Poly Vee … you may get more if you try just poly.
                            Edited By Michael Gilligan on 26/11/2013 13:35:12
                            #136479
                            ega
                              @ega
                              Thanks for your continued help. The search box at top right should come with a health warning or pointer to the Google search box as the present arrangement is counter-intuitive to say the least. You would think that one genuine use for the forum search would be to locate postings by particular members; however, a quick check against my own site name + "model engineer website" suggests that Google is more effective, although I have yet to explore the forum expanded search facility.
                              I found the Naismith website helpful on the tension point – thanks again.
                              #136481
                              ega
                                @ega
                                Bogstandard2
                                Thanks for your description of your belting system. I had not heard of the Redthane brand although I am familiar with the concept; on looking further I saw a reference to "Greenthane" also.
                                On the subject of shifting vee belts from sheave to sheave, this can be done with a suitable lever at the expense of belt life but the practice is frowned on and I don't think it would be possible in motion. Someone mentioned the use of link belting on the Super Seven, a method which I adopted some time ago. At the outset, I was disappointed to find that the bulkier section compared with standard vee belting prevented shifting between the large countershaft pulley sheave and its smaller neighbour and it was some time before I realized that this could be achieved by rotating the pulley backwards!
                                #136509
                                John Waterfield 1
                                  @johnwaterfield1
                                  Thanks to everyone for you replies. I was a toolmaker/engineer by trade, and the comments regarding the poly-V belts, I have always found that polypropylene/Nylon pulleys always need much more tension to drive, due to a certain type of oil used in the Manufacturing process, which is all right if you are using ball or roller bearings, but not on friction bronze/white metal bearings.
                                  In the mean time while i sort out the v-belt system i am going to use i shall replace the flat belt so i can use the lathe properly, for the belt that came with it, is a rubber belt, like a cars alternator and seems to slip all the time.
                                  If anyone could recommend the good make of a continues flat belt to use, i might be able to do some work. I will keep in touch, and let you know which way i go, and how it works out.
                                  Many thanks to all
                                  Regards John Waterfield
                                  Edited By John Waterfield 1 on 27/11/2013 01:40:04
                                  #136517
                                    John,
                                    I admit to being totally bewildered by your dismissal of PolyVee …
                                    To my mind this would be the ideal drive system for an updated ML4.
                                    That said; it's your lathe, so I shall not interfere any further.
                                    I wish you well, whichever route you choose.
                                    Edited By Michael Gilligan on 27/11/2013 08:38:23
                                    #136520
                                    Brian Wood
                                      @brianwood45127
                                      Hello John,
                                      Flat belts. A good number of years ago I needed to replace a 4 inch wide leather belt on a PTO driven circular saw that I used as a logging bench on my grey Fergie tractor. In the end I used the compound belting that is used on round bail making machines; it was absolutely ideal for the job..
                                      It might be a bit agriculturalin terms of thickness for your lathe but a narrow strip suitably joined might serve, I may even have the remnants in one of my hidden boxes which I'll look our for you.
                                      I'll PM you if I can find it and also scan the handbook in for you as requested.
                                      Regards Brian
                                      #136577
                                      John Waterfield 1
                                        @johnwaterfield1
                                        Michael
                                        You might be right, But i have always found that the ally V pulleys do just as good a job as the poly V, but with less pressure, i would imagine the poly V's might be cheaper, but as the lathe is quite old and with a certain amount or wear, i will treat the ML4 to a easier life
                                        JohnW
                                        #136579
                                        John Waterfield 1
                                          @johnwaterfield1
                                          Hi brian
                                          Many thanks for that,i look forward to hearing from you.
                                          Regards John
                                          #136584
                                            Posted by John Waterfield 1 on 28/11/2013 00:48:51:
                                            Michael
                                            JohnW
                                            John,
                                            Please forgive me labouring the point [especially as I said I would not] … but; for my own peace of mind, I need to check that we are talking about the same thing:
                                            What I was suggesting was that you modify your existing [Cast Iron ?] flat-belt pulleys, by machining the appropriate grooves to accept this type of belt. The J-section belt should be quite adequate for the purpose; and four-rib would probably suffice.
                                            Brian Wood
                                              @brianwood45127
                                              Hello again John,
                                              Check your message box please, I don't want to send the handbook by open forum despite the rather tired copyright that must now surely apply to lathe literature this old.
                                              Regards Brian
