Centre punch size
Centre punch size
Home Forums Beginners questions Centre punch size
  • #75397
    Wolfie
      @wolfie
      OK silly question alert!
      I want to buy a small centre punch at an online supplier. Thing is they are given in sizes ranging fron below 1/8″ to over 1/4″.
      What I want to know is what that measurement is? Is it the tip or what??
      #5670
      Wolfie
        @wolfie
        #75401
          I would say its measured at the top of the 90deg cone before the long taper starts so the 1/8″ one would be fine for small work.
          Edit if this is for your bit of 3/16 bar or any accurate work  then you should use a dot punch first as this makes it easier to shift the mark if you don’t get it spot on the first time. Once happy with teh dot punch hark follow it up with a centre punch
          Even then I now tend to use the DRO rather than mark out if it needs to be precise but its still good to learn the basics while saving up for a DRO.
          J
          Edited By JasonB on 25/09/2011 19:40:58
          #75407
          Wolfie
            @wolfie
            DRO??
            And whats a dot punch?
            #75409
            Sub Mandrel
              @submandrel
              Dot punch is like a finer, more pointed centre punch. Give it a light tap to make an accurate dot, then you can put the centre punch in the dot and give it a (little) more welly.
                Dot punch looks just like a centre punch but is more pointed – 60deg included angle vs 90deg. The point engages into the scriber lines better and as I said above can be pulled over by tilting slightly and hitting again if its not right first tile. Also gives a better hole for divider points to engage into.
                DRO Digital Read Out, use it on teh mill to vet very accurate hole positions.
                Edited By JasonB on 25/09/2011 21:48:45
                #75414
                DMB
                  @dmb
                  Wolfie,
                  Like JasonB said,dot punch lightly first, check its spot on then use centre punch with a slightly heavier bump with a small hammer. Note, you dont need to hit it hard and create a huge bomb crator and when using the dot punch, if its not exactly where it should be, lean punch over at an angle, pointing in the direction that the punch mark needs to be moved and give it a very light tap, check re-positioning OK then hold upright and give it a harder tap.
                  John.
                  #75415
                  Terryd
                    @terryd72465
                    Hi Wolfie,
                    A DRO is a Digital Read Out . These are digital scales fixed to some machines to show the accurate position of the tools or work. Typically a lathe will have one for saddle travel and one for cross slide. ( occasionally one for topslide) a Milling machine usually has one each for the X, Y and Z axes.
                    A ‘dot’ punch is a fine punch with a sharp angle (60 degrees included) point for accurately marking centres. A ‘centre’ punch has a more robust point with an included angle of around 120 degree included angle (about the same as a drill angle of 118 degrees) this gives the drill point a good location.
                    It is normal practice to use a dot punch first to lightly mark a centre (using a magnifying glass and light is preferable) and if accurate this is followed with a ‘centre’ punch to give a larger mark for the pilot drill to locate. If not accurate the light dot punch mark can be moved by tapping the punch at an angle in the direction it needs to be moved before finishing with a centre punch.
                    I make my own punches using some high carbon steel I have but they can be easily made from silver steel. PM me if you need advice and are interested. Here is an example made from some salvaged silver steel The bottom one is the home made punch. It too about 20 minutes from start to using:
                    In the past a dot punch would also be used to mark cutting lines on an an irregular piece or component and you would cut and file until you ‘halved’ the dot marks and then remove the half marks by chamfering the edges of the work.
                    Hope this helps, us old timers take too much for granted. If you need any more advice don’t be afraid to ask.
                    Best regards,
                    Terry
                    #75428
                    Ian S C
                      @iansc
                      I find that the little dot punchs that I make out of old chainsaw files are very handy for small work. The files I use are 3/16″- 5mm and 1/4″- 6mm , I seem to find worn out files turning up quite often.
                      At school metalwork classes, our teacher got us to dot punch the lines to file to, and he inspected all our work, and expedted to see half the dot. Ian S C
