TA8435H stepper driver
Home Forums Beginners questions TA8435H stepper driver
  • #4820
    ken lyall
      @kenlyall56141
      #44703
      ken lyall
        @kenlyall56141
        Does anyone have any infomation on these drivers and how to hook up the limit switches to these ?
        cheers Ken
        #44707
        John Haine
          @johnhaine32865
          Ken, these are just the driver ICs, looking at the data sheet.  You would normally connect the limit switch to the software that drives the drivers, for example to the Estop input if using Mach 3.  Info on the IC is available at:
          John.
          #44716
          John Stevenson 1
            @johnstevenson1
            I think he means one of these.
            Looked at the setup.doc and found no input signals at all including E-stop
            John S.
            #44722
            John Haine
              @johnhaine32865
              Hmm.
              That page links to this:
              which describes the unit with the connections including the usual enable/direction/step inputs.  Also describes use of Mach 3 and the unit comes with a copy of Mach 3!  Obviously expect you to use the normal E-stop via a break-out board.
              John.
              #44739
              John Stevenson 1
                @johnstevenson1
                Look carefully this is a combined driver and breakout board hence the parallel port input,
                Can’t have this and a breakout board on the same cable.
                John S.
                #44840
                ken lyall
                  @kenlyall56141
                  Thanks guys
