Opions sought on using the USB Photo Stick for photo storage
Home › Forums › The Tea Room › Opions sought on using the USB Photo Stick for photo storage
Viewing 25 posts - 1 through 25 (of 36 total)
  • #36000
    Greensands
      @greensands
      #488104
      Greensands
        @greensands
        Hi all – Has anyone had any experience in buying and using the USB photo storage system such as "Photo Stick" or similiar device? Most of the reviews I have seen have been from the US. Not sure where they might be availablefrom in the UK
        #488111
        Ian Parkin
          @ianparkin39383
          Are you not able to find your photos and transfer them to any usb stick?
          all the photo stick does ..it has a piece of software on it which searches for jpeg files and transfers them for you..
          if you can do it yourself it saves lots of money
          #488115
            Posted by Ian Parkin on 29/07/2020 10:55:33:
            All down to the cost. As long as the storage isn't overpriced, it's a very easy way of backing up photos. Not so sure it would be quick to find a particular photo again but that's a problem with all backup systems. (And all those boxes of 35mm slides in the loft.)
            Reminds me – must do a backup! Photos are the least of my problems if a disc goes pop.
            Ady1
              @ady1
              I use Integral sticks for important stuff, swiss bank account numbers, bitcoin addresses, photos, pdfs etc
              Not had a single failure yet, (about 2005 for my 2MB sticks) and they are reasonably priced
              Up to about 128GB nowadays
              #488118
              roy entwistle
                @royentwistle24699
                You can get independent hard drives for not much more than USB sticks. I save JPEGs on a CD and RAW files on a independent HD. I print thumbnails of all JPEGs and label them so I can find them if needed
                #488125
                Greensands
                  @greensands
                  Do they only work on JPEG files or can they also be used to store data files and the like?
                  #488132
                  Anthony Knights
                    @anthonyknights16741
                    USB memory sticks/thumb drives or whatever else you care to call the are just blocks of non-volatile memory that you can store data on. I have USB memory with DVD's stored on them, but you have to use NTFS format as the old FAT32 format cannot handle files larger than 4GB. My computer hard drives are backed up onto memory sticks as well as onto spare HDDs.
                    #488133
                    roy entwistle
                      @royentwistle24699
                      They can store any sort of file. provided that they are big enough I've got Microsoft Office XP on one.
                      #488150
                      Circlip
                        @circlip
                        I only use sticks as a transfer medium, Have external hard drives for “Storage”. 1Tb drives are cheap now.
                        Regards Ian.
                        #488154
                          Posted by Greensands on 29/07/2020 12:36:22:
                          It's an ordinary USB Memory Stick with a pre-loaded application. When the stick's plugged in, File Manager starts (as usual), and the user double clicks the application. The software scans the disc for all the common media files, not just jpg, and copies them on to the memory stick. I guess it's clever enough not to copy files more than once, so it builds an ongoing archive of photos as they're added to the PC. As there's nothing special about the Memory Stick any files on it can be read, written and deleted in the usual way.
                          The attraction is extreme ease of of use. Doesn't do anything that couldn't be scripted by a programmer, or by any of the many back-up/restore tools. But general purpose backup tools are complicated compared with this. Clever idea: a super-simple way of copying photos for safe-keeping; so simple I'm amazed it's not been done before.
                          Nick Clarke 3
                            @nickclarke3
                            I too have been using USB sticks since they first became available and I have a 64M one here that is still working from years ago. The advice to buy quality is reasonable, but in the day job I buy between 30 and 50 a year, usually Kingston and there are still failures after repeated use, even after fairly short periods of time. These seem to be more often down to software on the computers using them as the sticks will usually reformat with the appropriate software, but by then all of the data is lost.
                            Portable SSDs are basically the same thing, and over the years I have had several hard disk failures.
                            Saving to the cloud is quite reliable, but unless you have a paid account check to see what your provider guarantees – it is often very little!
                            The only way to totally guarantee your data is through two things – Firstly redundancy – save your data in two or more places and refreshing – rewrite you data from time to time.
                            It is up to you to decide how much your data is worth. At home I back up to two different NAS storage systems every so often, and the main one of these is a RAID array.
                            If this sounds a pain remember that when we used film we all had boxes of negatives and prints or transparencies that, short of a fire, were permanent. Now we use digital photography we are sometimes hard pressed to keep digital files for more than a few years or so. The life of re-writeable CDs and DVDs is 10-15 years as blank disks, CD-R or DVD-R recorded data will be safe for more than 100 years but in the case of the – RW versions it is apparently only 25 years or so.
                            If that sounds like a long time remember that the first photo of Niépce in 1826 still exists and my own wedding photos if they had been stored on DVD-RW, had such a thing been available then, might not be readable today!
                            #488177
                              I use sophisticated backup software for all my business files (Macrium).
                              I also use Microsoft File History (although it has an uncanny ability to switch itself off). I just checked and it hasn't run for two days despite telling me it's set to run every hour.
                              I am still searching for a simple piece of software that will maintain an external drive as a mirror of my main disk, and automatically update of I swap that drive for another one.
                              My concern is always to have a backup no more than a week old that isn't connected to the computer.
                              Steve Neighbour
                                @steveneighbour43428
                                I used to use umpteen USB memory sticks, and then ended up with far to many.
                                Moved almost all of what I value to a cloud based storage system (Dropbox and other similar providers) and also have a WD 'Home Cloud' which is connected to my router via a 256 bit firewall for security, this has 8TB of space, so I doubt I'll fill it anytime soon. It also has a 'mirror' drive as back up in case one falls over.
                                Just google 'My Cloud'
                                The advantage is the TV can access it for films, photos etc, my smart phone for backing up every picture I take (automatically) and my PC for everything else,
                                The great advantage is I can access stuff from home, work, and anywhere worldwide.
                                When my time comes to go to the 'workshop in the sky' my kids will just inherit a Lathe and Milling machine (they won't really want them I suspect) and a few passwords on a post-it note (if I can remember them by then !!)
                                Steve
                                Edited By Steve Neighbour on 29/07/2020 19:58:18
                                #488194
                                Enough!
                                  @enough
                                  You (Greensands) could get a decent search program and do a full computer search for files with graphics filetypes. A good one will should let you search multiple filetypes concurrently. You should then be able to copy all those files from its listing to the USB card of your choice in one swell foop.
                                  That's basically all Photo Stick does … it just saves you the trouble of remembering all the different graphics filetypes. Chances are you neither use not care about most of them.
                                  Edited By Bandersnatch on 29/07/2020 22:55:29
                                  #488208
                                  Grindstone Cowboy
                                    @grindstonecowboy
                                    Posted by Neil Wyatt on 29/07/2020 19:42:07:
                                    Neil – you could do worse than have a look at Karen's Replicator available here. It may do what you require.
                                    Free for home use and not very expensive for a work license. I've been using an old version for years – didn't even realise there was a newer version until I went looking for a link to post here – and it's simple, lightweight and reliable. Sadly the author passed away quite a few years ago, but someone seems to be maintaining and improving her various "Power Tools", although in all honesty I can't think what could be improved in the Replicator.
                                    Rob
                                    #488214
                                    Ian Usmar
                                      @ianusmar79339
                                      Does anyone know if "Karens Replicator" will work on the Mac ?
                                      #488221
                                      AdrianR
                                        @adrianr18614
                                        I am not a Mac user but at work, they used Time Machine which Mac's come with.
                                        #488224
                                        Peter G. Shaw
                                          @peterg-shaw75338
                                          I have what is essentially a manual system based around two computers along with their internal hard disks, and two external hard drives.
                                          The original idea was to have a spare computer just in case the main computer failed. The system then blossomed into a system whereby there are two copies of everything I want to save associated with each of the two computers, one on the machine itself and one on an external hard drive. So four copies in all. Both computers, although not identical machines, are more or less identical in terms of software.
                                          Photos, including some ancient & clapped out 35mm colour slides which have been transferred to electronic & cleaned up, are kept in a single folder with sub folders for various categories. Probably the biggest problem I have is determining where a particular photo was taken – to this day I have a slide photo of our two eldest children along with a caravan somewhere, and I cannot determine where or when it was taken.
                                          The actual duplication of files for backup purposes, and let's face it, when I'm gone, it is unlikely that anyone else will wnat this stuff so it's mainly for my security, takes about 2 hours once a week.
                                          Happy snapping,
                                          Peter G. Shaw
                                          #488230
                                          Frances IoM
                                            @francesiom58905
                                            I have some 200,000 photos of documents done for research over 20+years (easier to photo in archives + read etc at home) – just choose a good long term stable linux system (eg Mint or Debian) + database (in my case this is an old Filemaker than has now been used for 25yrs) + merely duplicate harddrives overnight – linux unlike windoze or apple allows transfer of hard drives between cpus – in my case Lenovo laptops of various vintages none of which cost me more than ?120 + often less + a collection of desktops for various duties (eg in absence of a special hd duplicator to duplicate hard drives using dd command.
                                            Edited By Frances IoM on 30/07/2020 09:31:03
                                            #488232
                                            Steve Withnell
                                              @stevewithnell34426
                                              I don't like manual backups of anything, because they get forgotten and the media lost. I have a load of USB sticks. Somewhere.
                                              Cloud storage is often free depending on storage requirements and fully automated and 'always on'.
                                              If you are like me and can't quite make the move to moving the electronic copy of my life onto some remote hard drive, then you can buy a NAS drive and have the 'cloud' copy tucked away in the house. I use 'Allways Sync' so that hard drive always contains upto date copies of work from any of my devices. The weakness in that plan, is that I make manual copies of the remote drive onto a portable hard disk once a quarter and then lock that away, off network.
                                              Manual sticks I only ever use for file transfer – typically from the Laptop that generates gcode to the PC in the workshop that runs mach3, though I am tempted to put the workshop PC onto the network and get rid of those sticks altogether, because the temptation then is to alter the drawings on the stick, which then don't match the 'Final' versions on the laptop.
                                              The irony is that I first got involved connecting cnc machines to ethernet to eliminate paper tapes in 1983/4 so I'm a bit behind at home!
                                              #488237
                                              Grindstone Cowboy
                                                @grindstonecowboy
                                                Posted by Ian Usmar on 30/07/2020 07:47:07:
                                                I'm not a Mac user, but I don't think it will straight out of the box – however it might work under some sort of Windows emulator, but that's a whole extra level of complexity.
                                                Rob
                                                #488241
                                                Russell Eberhardt
                                                  @russelleberhardt48058
                                                  Have a look at MEGAsync. Will automatically sync any folders on your computer with cloud storage. You can also set it up on your mobie phone to automatically upload photos (only when the phone is on charge so as not to flatten the battery). All free of charge for up to 50 Gb IIRC.
                                                  Russell
                                                  #488252
                                                    Could you use Acronis to back up to an external HDD, say every hour, if that is what you wanted?
                                                    But it will probably overwrite the existing file with the new one.
                                                    #488270
                                                      Difficult to mirror discs without hardware RAID or SAN without trashing performance, and even harder to support hot plugging without them. I don't think Windows consumer versions have ever supported RAID & hot-plugging (both Windows Server technologies), but Windows 10 added mirror capability, worth a look maybe. It comes close, apart from the "isn't connected to the computer requirement".
                                                      Linux is much better at this sort of server stuff. Unfortunately far too advanced for soft-boiled Windows fans who prefer warm baths to bracing cold showers…
                                                      smiley
