Artistic hand cut oilways
Home Forums The Tea Room Artistic hand cut oilways
  • #481793
    Ian Johnson 1
      @ianjohnson1
      I'm helping to refurbish two very old steam engines on a 1903 coal fired steam tug boat, and when we stripped the starboard pump down I couldn't help but to be impressed with the hand cut oilways.
      So let your creative juices flow when cutting your oilways, they don't have to be straight!
      IanJ
      #35955
      Ian Johnson 1
        @ianjohnson1
        #481796
        Grindstone Cowboy
          @grindstonecowboy
          Just looking at that gives me a haddock!
          I'll get me coat…
          #481817
          Ian Johnson 1
            @ianjohnson1
            I thought there was something fishy about it!laugh
            #481820
            Mark Rand
              @markrand96270
              We don't teach children and youfs to use chisels anymore. We should do!
              #481821
              Paul Kemp
                @paulkemp46892
                That came off a trawler originally. Designed to be run on cod liver oil! devil
                Paul.
                #481824
                Grindstone Cowboy
                  @grindstonecowboy
                  If you ever get it running again, it'll be a mackerel.
                  I know my plaice….
                  #481825
                  Ian Johnson 1
                    @ianjohnson1
                    People are having a whale of a time here with some great fishy puns but cod do better cheeky
                    #481827
                    Ian Johnson 1
                      @ianjohnson1
                      Posted by Mark Rand on 23/06/2020 22:50:06:
                      Maybe we should have a competition for the most artistic hand cut oil ways?
                      I've seen a couple of youtube videos where people have spent ages meticulously setting up top slides on the mill to machine precise oilways, when it would have been a lot quicker to get the bullnose chisel out and cut some curvy grooves, it will achieve the same result.
                      #481838
                      RichardN
                        @richardn
                        Posted by Ian Johnson 1 on 24/06/2020 00:04:35:
                        …cut some curvy grooves, it will achieve the same result.
                        Will the curve be better at distributing the oil? Or is there no difference in result?
                        or perhaps negligible difference at workshop loadings and immeasurable?
                        …sorry I codn’t add a fishy pun…
                        #481839
                          They'll just 3D print some oilways up after a quick CAD session scanning in a haddock and computer generating a tool path. Steam engines have moved on since your day , grandpa.
                          #481842
                          NIALL HORN
                            @niallhorn50878
                            It's an Icthys – obviously designed to give divine support in the machine's subsequent life.
                            #481848
                            Ian Johnson 1
                              @ianjohnson1
                              I don't think it matters too much what shape the oilways are as long as the oil is distributed on the surfaces.
                              An Icthys! I never thought a boat would need divine support, I thought that was what the water did frown
