Do remember that you can still take up floor space under the extended table by running benches upto the edge of the stand or simply standing it on a bench so floor space will be cabinet size but working space will be more.
Same applies to the depth you only need to take up enough floor/bench to stand the base on, no problem if the handle overhangs the front, I have the SX2.7 on a 500mm deep bench yet it's depth is over 600mm.
Edited By JasonB on 08/07/2019 07:32:52
Edited By JasonB on 08/07/2019 07:39:54
