Hi Everyone,
I,m sure everyone remembers the on-going-saga of my rotary table.
I decided to address the problem,and having discovered that the center bush is hardened,was unable to machine it true,using an end mill on the milling machine. So I then set about dismantling it to try pressing out the bush,using a 10 ton press. I got most of it apart [never seen the inside of it before ],but was still unable to get at the back of the center bush. I can see the underside of the bush but there is another piece,the wormwheel?,in the way. This seems to be held in place by four screws,which I removed but could not remove the item itself. The center shaft appears to be part of this unit and that,s what prevents access to the bush. At that stage I held fire and decided to refer to a higher Authority,namely,your good selves,having put my lump hammer away,for the moment.
Can anyone out there throw any light on this,as to how this thing comes apart ? Since it is held in place by screws,it must be a separate piece and it seems to be the only thing left to remove. I,ve no doubt that someone has taken these things apart many times.
I did consider trying to bore out the bush on the lathe,in order to get back to the cast iron body and then trueing it up on the mill,but I suspect that the boring bar would have a hard time,if indeed it would work.
All help and advice welcome. [The hammer is still to hand,should all else fail !]
