ER collet adapter
ER collet adapter
Home Forums Hints And Tips for model engineers ER collet adapter
  • #474161
    Redpiperbob
      @redpiperbob16487
      Hi there I thought this information might be useful to others.
      I recently bought an ER20 collet adapter for my Myford Super 7 lathe from RDG Tools. The box contains a threaded adapter for the lathe mandrill, a collet body and a collet nut.
      What you are supposed to do is screw the adapter to the lathe mandrill then turn down the boss of the adapter to match the collet body (I also put a small relieve at the base of the register). I then screwed the body to the adapter and measured the run out.
      I was getting 12 thou runout. I took the collet body off and measured the register it had less than half a thou runout.
      I then refitted the body but did not fit the screws supplied with the kit. No runout. I then tightened the screws (carefully) and I got the 12 thou runout again. I then got three screws from my stock and fitted them, no runout. I then looked at the screws that came with the kit and noticed that the heads were not parallel with the threads. I throw them out. Job done and now less than .5 of a thou runout.
      I just thought this maybe useful to someone else.
      Bob
      #30737
      Redpiperbob
        @redpiperbob16487
        #474167
        bernard towers
          @bernardtowers37738
          Just goes to show you get what you pay for even in fasteners. I machine a lot of stainless socket heads for HD’s as in the supplied state the heads can be up to 20 thou eccentric!! It would never have occurred if they had supplied Unbrako’s.
          #474180
          Journeyman
            @journeyman
            Glad you got the problem sorted. Hope the "Mandrill" didn't get too stroppy:-
            They tend to get a bit grumpy cheeky. On the other hand a mandrel is usually OK with being used to support a job on the lathe or being hammered on! The lathe spindle on the other hand does not appreciate being used to form sheet metal but the spindle nose is quite alright about having chucks screwed to it.
            ( Apologies in advance for any distressed feelings but couldn't miss the photo opportunity! )
            Redpiperbob
              @redpiperbob16487
              Damn Microsoft spell checkerangry
              Bob
              #474220
              old mart
                @oldmart
                If somebody posts a picture of the other side of the mandrill, it will be just as colourful. devil
                Leaving a bit of play in the register and the screw holes gives you the option of getting everything running perfectly, even if one of the collets is less than perfect. With an eccentric collet, you would have to re align every time it was used as there is no way of indexing the collets in the holder.
                #474277
                AdrianR
                  @adrianr18614
                  Possibly as colourful as Bob's language when he found the problem wink
                  Adrian
                  #474279
                    That's what happens when you start to monkey about with things!
                    #474396
                    CHARLES lipscombe
                      @charleslipscombe16059
                      A bit off-topic but tip I picked up from another post – use a Stevenson's collet block mounted in a 4-jaw chuck. The amount of time and trouble this idea has saved me is incredible. It is also a lot cheaper than some of the alternative collet holding devices out there
                      Chas
                      #474406
                      Redpiperbob
                        @redpiperbob16487
                        Hi Chas thats what I have been doing up until this purchase.
                        Bob
                        #474412
                          Posted by Redpiperbob on 23/05/2020 11:03:36:
                          Bob
                          Thanks, Bob … It tells us a lot yes
                          but I’m not going to labour the point.
                          Kiwi Bloke
                            @kiwibloke62605
                            Perhaps I'm being a bit thick, and have missed something important, but I would expect this set to be designed so that the collet body is kept in radial alignment by a register on the adaptor. I'd expect the user to have to turn the register's diameter down to size, and also to face the adaptor. Then, surely, even 'wobbly' screws – if they fit the holes – will not derange alignment.
                            #474446
                            Redpiperbob
                              @redpiperbob16487
                              well they pulled mine off
                              #474453
                              Kiwi Bloke
                                @kiwibloke62605
                                I'm not doubting your observation, but I'm struggling to understand how. [I like to understand things – it's a failing…] The supply of obviously defective screws with the kit would raise my suspicions to danger level, and I'd be going all over the thing with an impressive array of metrology gear. Or wondering whether to return the thing…
                                Edited By Kiwi Bloke on 24/05/2020 10:47:45
