Replacement motor for Lathe
Home › Forums › General Questions › Replacement motor for Lathe
  • #658117
    barry
      @barry
      Hello,
      I have just bought a Myford ML2 I think. It came with a very old motor. The specifications on the motor are HP1/4, volts 220, amps 2.6, cycles 50, revolutions 1450. I do not like the look of the wiring so I have a spare motor rated at Amps 1.5, HP 1/3, revolutions 1420, HZ50, volts 230.
      Would this be a suitable replacement for the old motor?
      #29348
      barry
        @barry
        #658120
        Ady1
          @ady1
          The newer motor is fine
          Your main challenge will be sorting out the lathe, use a slack belt to start with until you get some familiarity
          Edited By Ady1 on 26/08/2023 22:43:08
          #658129
          bernard towers
            @bernardtowers37738
            Surely the wiring only goes to the terminal box?
            #658155
            Tony Martyr
              @tonymartyr14488
              Faced with a failing motor on my 1962 Myford lathe I replaced it with a Newton Teslar CL400 variable speed drive and motor. A very easy direct replacement that has transformed my work on the lathe by being able to dial in any chuck speed for tapping, turning and polishing.
              #658161
              Dave Halford
                @davehalford22513
                Posted by barry on 26/08/2023 22:22:56:
                Hello,
                Yes depending on the motor spindle size matching.
                #658243
                old mart
                  @oldmart
                  Lucky you, to have an ideal replacement, good turning.smiley
