Allchin 11/2″
Allchin 11/2″
Home Forums Traction engines Allchin 11/2″
  • #87649
    Bryan Cedar
      @bryancedar96259
      Having almost completed the refurbishment of an Allchin by W J Hughes, I have only just discovered that what I thought were roundhead rivets turned out to be shoulder bolts in steel threaded 5BA on the ends and fitted with 5BA steel nuts without washers. The bolts appear to be over long, should these be trimmed?
      The person who sold me the engine informs me that his club members prefer this method as opposed to copper rivets as it allows dismantling if necessary.
      Can members advise if they agree with this method of construction.
      I may not steam this engine but wish it to be in steaming order.
      #2740
      Bryan Cedar
        @bryancedar96259
        Firebox stay rivets or bolts.
        #87650
          Bolting the hornplates on through the hollow stays is quite common, the stays can either have an internal thread and then the nut acts as a lock nut or be a plain bore with the nut being used to retain the bolt. It won't hurt to trim off the excess.
          BTW the minnie in my avitar uses bronze studs and nuts to hold the hornplates and the Fowler I'm working on has button head screws into tapped stays with a locknut inside.
          J
          Edited By JasonB on 20/03/2012 13:34:55
          #87654
          Bryan Cedar
            @bryancedar96259
            Many thanks Jason, thats reassuring.
            Bryan
          Home Forums Traction engines Topics
