Help identifying thread
Home Forums General Questions Help identifying thread
  • #472097
    Chris Shelton
      @chrisshelton11794
      Hi I have a thread on an American made car diagnostic probe, which I am having trouble identifying, the major diameter is 4mm or .1580" it is 32tpi. can anyone help, I need to purchase a tap to suit, have looked on the internet, but cannot match the details.
      Thank you
      #27363
      Chris Shelton
        @chrisshelton11794
        #472099
        Tony Pratt 1
          @tonypratt1
          Most likely 8-32
          Tony
          #472103
          Marischal Ellis
            @marischalellis28661
            poss UNF does that help.
            #472115
            mechman48
              @mechman48
              Try:-
              ANF ( 60* ) #10 = 32TPI
              2 BA = 4.0 mm / 0.1575
              George.
              #472116
              Chris Shelton
                @chrisshelton11794
                Hi, Thank you for the replies, just found my engineers Black Book, and it looks as if it could be 5/32 BSW, which is not listed in Zeus
                #472118
                Tony Pratt 1
                  @tonypratt1
                  Hi Chris, 2 points, the yanks would not use BSW & .158" is bigger than 5/32" that being said it will work.
                  Tony
                  #472119
                  Clive Brown 1
                    @clivebrown1
                    5/32" BSW is Meccano thread. Seems unlikely on an American gadget.
                    #472120
                    Anonymous
                      Given it's US made I'd bet it's 8-32 UNC.
                      #472124
                        Zeus Charts give 6-32 ANC as having an OD of 0.138", and 8-32 as 0.164" The thread form will be 60 degrees
                        There is no ANF thread with 32 tpi pitch.
                        It could be 10-32 UNF which is 0.164" diameter, but slightly truncated to give the 0.158" OD.
                        If it were 4mm it would be 0.15748" diameter, but M4 is 0.7mm pitch which is 17.78 tpi.
                        HTH
                        #472128
                        Jeff Dayman
                          @jeffdayman43397
                          Howard Lewis – your third sentence – #10-32 UNF is NOT .164" diameter, #8-32 UNC is .164" diameter
                          #10-32 UNF is .190" diameter
                          #472131
                            Quite RIGHT,
                            I misread from one line to the next
                            Sackcloth and Ashes again!
                            So looks like 8-32 UNC as a likely candidate.
                            #472136
                            Chris Shelton
                              @chrisshelton11794
                              Thank you all for taking the time to reply, I have ordered a 5/32 BSW set of taps, as Tony P said it will work.
                              #472149
                              Tony Pratt 1
                                @tonypratt1
                                Posted by Chris Shelton on 16/05/2020 13:24:56:
                                If it doesn't work I will refund your moneycheeky or send you an 8-32 tap.
                                Tony
                                Edited By Tony Pratt 1 on 16/05/2020 13:49:57
                                #472151
                                Pete Rimmer
                                  @peterimmer30576
                                  Posted by Howard Lewis on 16/05/2020 12:55:37:
                                  HTH
                                  Sorry to be a correction-ist Howard but I think you multiplied instead of dividing there. 0.7mm pitch would be 36.28tpi
                                  #472161
                                  Former Member
                                    @formermember32069
                                    #472169
                                      This is a great explanation of the different systems from an American perspective.
                                      http://www.rustmag.com/gear/2018/1/4/threads-and-thread-systems
                                      With one exception UNC and Whitworth are the same, except for the flank angles.
                                      <edit> I forgot the link!
                                      Edited By Neil Wyatt on 16/05/2020 15:15:59
                                      #472216
                                      Chris Shelton
                                        @chrisshelton11794
                                        A local friend came to my rescue with a 5/32 BSW tap, after tapping the part it screwed onto the probe about half a turn, so have now ordered, an 8-32 tap, can someone tell me what the 8 in the 8-32 stands for?
                                        Tony I will not hold you to your promise of a refund, after all I could tap some Meccano parts now.
                                        #472223
                                        Former Member
                                          @formermember32069
                                          #472224
                                            below 1/4" dia UNC & UNF use a number system a bit like old wood screws and BA threads, the higher the number the larger the thread.
                                            #472234
                                            Tony Pratt 1
                                              @tonypratt1
                                              Posted by Chris Shelton on 16/05/2020 17:23:33:
                                              Thanks, let us know if the 8-32 does the trick, 5/32 BSW is slightly smaller on diameter, maybe that is the problem.
                                              Tony
                                              #472405
                                              Chris Shelton
                                                @chrisshelton11794
                                                Thank you Jason for the explanation, and Tony P will let you know the outcome when my tap arrives at the end of next week.
                                                #473255
                                                Chris Shelton
                                                  @chrisshelton11794
                                                  Thank you,
                                                  To all who took the time to answer this query, 8-36 tap arrived today, and the threads do match.
                                                  Edited By Chris Shelton on 20/05/2020 14:41:00
                                                  #473281
                                                  Tony Pratt 1
                                                    @tonypratt1
                                                    Posted by Chris Shelton on 20/05/2020 14:40:41:
                                                    Thank you,
                                                    Wasn't it 8-32?surprise
                                                    Tony
