What is it
What is it
Home › Forums › General Questions › What is it
  • #26869
    john brown 17
      @johnbrown17
      #431502
      john brown 17
        @johnbrown17
        img_20190804_101913.jpgimg_0102.jpgAny clues please
        #431504
        Phil P
          @philp
          I dont know but I want one !
          Phil
          #431505
          john brown 17
            @johnbrown17
            Another one?
            Edited By JasonB on 02/10/2019 18:32:35
            #431506
            Clive Foster
              @clivefoster55965
              Looks to be some sort of adjustable offset indexing device although there is no obvious means of holding a workpiece to it. Unless the central screw is simply a blanking plug to protect a threaded bore into which suitable carriers can be fixed.
              I had a similar device made many years ago as part of what could be called a laser protection filter test rig so that multiple tests could be made on one sample and damage objectively evaluated.
              #431507
                Could they be some form of slotting tool for cutting internal splines.
                Depth of cut on the first one is done like a boring head and the second one would have a similar arrangement. You then index the cutter round for the number of splines required. Drive it in and out on a slotter or manual rack and pinion, maybe even horizontally on a shaper
                #431509
                  The first looks very similar to one of the Deckle punch milling attachments.
                  #431511
                  john brown 17
                    @johnbrown17
                    Well l have looked at them for weeks,but do think jason is right about the tool for cutting internal splines,as for the other one have not got a clue ,l did think about altering it to use in the tail stock for taper turning,but will se if anyone knows what it is before l play with it.
                    john
                    #431515
                      Is that small "boring head" ty etool in the second photo actually being held in a collet, similarities to this Aciera accessory
                      #431516
                      old mart
                        @oldmart
                        Clive Fosters first paragraph beat me to the post, its exactly what I would have written.
                        And Jason B beat me with his thoughts about the second one.
                        #431520
                        john brown 17
                          @johnbrown17
                          Yes jason its held in with a collet,have also got some very small boring bars with it,that go in the head
                          john
                          #431533
                          peak4
                            @peak4
                            Re, the first one, the table on my Meddings high speed drill sits on a similar boss
                            This could replace the table, depending on size, and allow a circle of holes at a fixed pcd, adjustable via the dovetail slide.
                            Is there a sensible number of slots, say 36 to give 10º spacing, or 24 to give a 15º spacing?
                            Alternatively for holding cutters or saws on a tool and cutter grinder, either for sharpening, or making in the first place.
                            Bill
                            #431561
                            john brown 17
                              @johnbrown17
                              Yes bill there are indeed 24 slots on the tool,to me it looks like it was factory made ? with its chrome part on it and the finish ,its just knowing what it was for and if it is still of use to anyone before l play with it.
                              john
                              #431618
                                First one can also become the basis for an ornamental turning 'eccentric chuck' which might be what you were thinking of doing with it.
                                #431644
                                Bill Davies 2
                                  @billdavies2
                                  Well, neglecting the small boring head, the second one looks like it could be a cutter grinder attachment. The hex brass piece and the rod through it may be part of the spring-loaded blade for indexing off the cutter, rather than using fixed division plates. For example, if the flutes were not evenly distributed, as in some anti-chatter reamers. When I sharpened cutters, this was the method used, both on new ones being ground for the first time, and for subsequent re-sharpening.
                                  #431661
                                  john brown 17
                                    @johnbrown17
                                    Hi bill ,the brass hex piece an rod ,just lock the spindle as you index it ,l think that tool will have a use ,had another look today and it will fit the tee slots on the myford,so could be handy for small boring work,just a thought.
                                    john
