Vega Twin
Vega Twin
Home › Forums › I/C Engines › Vega Twin
  • #550426
    Alan Gordon 4
      @alangordon4
      Good morning chaps
      This question is really directed at any one who has built this engine. I am slowly but surely working through the construction of my Vega Twin. When I first got the plans I noticed that there was described on the plan "Mounting Plates". measuring 3" x 1.5" x 1/8 with two 2 BA tapped holes 0,375 apart in the centre. There is also shown two cut outs either end of the plate. For the life of me I cannot see what this plate is used for or where it goes. It is probably staring me in the face but any help from Vega builders would be appreciated.
      #2610
      Alan Gordon 4
        @alangordon4
        Vega Twin
        #550445
          I have a feeling it is used to mount the cylinder heads (via valve holes) for one or more machining operations.
          #550457
          Roderick Jenkins
            @roderickjenkins93242
            Hi Alan,
            I have sent you a personal message.
            Cheers,
            Rod
            #550464
            Buffer
              @buffer
              Alan
              I can see there are a few pictures in your albums but what about some regular updates and photos? I know myself and many others would love to watch this coming together.
              #550477
              Alan Gordon 4
                @alangordon4
                Hi Buffer,
                You know it genuinely never occurred to me to do this ! I am attempting the carbs at the moment and if it would be of interest I would be pleased to post a few photos. This build has been (almost) a death by a thousand cuts. but I would be pleased to offer any advice on the build to anyone undertaking this project.
                #550488
                Buffer
                  @buffer
                  Alan
                  Honestly it would be brilliant to see this being built. There is another member building a twin victoria with nearly 18000 views! I'm sure people would love it.
                  #550547
                  Alan Gordon 4
                    @alangordon4
                    20210620_095613.jpg20210620_095538.jpgHi Guys, Thought I would post a few photos of the Vega progress. I struggled with making the exhausts so trip to B&Q and a visit to the plumbing section got me a couple of these 22mm copper end caps. I took each cap and drilled the 1/4" holes either end. I then cut one cap down to give me the required length as per the plan. I joined the halves together using a nut and bolt and silver solder together. Not as elegant perhaps but maybe a wee pollish will help.20210620_095503.jpg
                    Edited By Alan Gordon 4 on 20/06/2021 10:21:33
                    #550551
                    Former Member
                      @formermember12892
                      #550561
                        Engine is looking good, a bit of black BBQ paint is another option for exhausts and silencers.
                        #550570
                        Alan Gordon 4
                          @alangordon4
                          Hi Jason,
                          Thought about that, but on the assumption that it will run !!!!! I was concerned that the paint would peel off due to heat,
                          However I was thinking about using a car / motorcycle exhaust paint which I assume would be more resistant,
                          If anyone has other alternative ideas ?
                          #550576
                          Emgee
                            @emgee
                            Nickel or chrome plating may look good but I would just use some black heat resistant paint.
                            Emgee
                            #550579
                              The BBQ paint is heat resistant. I use a stove paint and have not had problems with that coming off exhausts
                              #553485
                              Alan Gordon 4
                                @alangordon4
                                Good morning everyone,
                                Well, here I go again.
                                This I hope is the last query I have with regards the plan ? The plan shows each carb body having two 8ba holes drilled, again I cannot see what they are for, and like the mountings plates previous any advice would be gratefully received. I will post pics soon of the carb build if of interest. Thank you all in anticipation.
                                Got the stove paint Jason, thanks,
                                #553490
                                  One hole takes the slow running screw and adjusts how much of the air bleed hole is uncovered.
                                  The other takes the screw and washer to retain the barrel
                                  #553497
                                  Alan Gordon 4
                                    @alangordon4
                                    Ah, I see Jason, you know I looked at this and had brain fog, it's an age thing.
                                    Many thanks
                                  Home › Forums › I/C Engines › Topics
