Silverflo 55 Flux
Silverflo 55 Flux
Home › Forums › General Questions › Silverflo 55 Flux
  • #190103
    steve whedon
      @stevewhedon36834
      I was just wondering if Silverflo 55 flux has a shelf life. I have a plastic tub of the stuff still in powder form. It is at least 20 years old. Sorry if I have given it an incorrect title but that is what is written on the tub with a felt tip pen!
      #23889
      steve whedon
        @stevewhedon36834
        #190154
          Should be fine if kept dry.
          Keith Hale
            @keithhale68713
            Hi Steve,
            You are correct – Silverflo 55 flux does not exist!
            You have a flux that has been used in the past with silverflo 55.
            It could be either a low temperature short life flux or a higher temp long life flux. Not knowing your brazing requirements, it is impossible to suggest the best alternative either EF flux or HT5.
            Sorry Neil,
            but both have a long shelf life made longer by the addition of a little detergent and water to make a yoghurt consistency paste. When this dries out (and it will) it can be reconstituted with a little more water.
            No need to throw it away when it dries as hard as a brick!
            Keith
            #190180
              Well I figured that out for myself
