Any one know what this is and what’s it used for?
Home Forums General Questions Any one know what this is and what’s it used for?
  • #145826
    rebekah anderson
      @rebekahanderson95322
      found this his and looks interesting but what is it and what's it used for.
      i have an idea but don't know for sure. The owner doesn't appear ton know.
      cheers
      becky
      Edited By JasonB on 03/03/2014 14:28:44
      #23178
      rebekah anderson
        #145830
        John Stevenson 1
          @johnstevenson1
          Looks like a bomb sight off one of your aircraft.
          PUT IT BACK !!
          #145833
          Speedy Builder5
            @speedybuilder5
            Is there a manufacturer's name on it. Looks like some sort of measuring device for surface finish (CLA ?).
            BobH
            #145844
            rebekah anderson
              well it came up during a search for 'Myford'
              I believe it's a lathe attachement.
              #145846
                Problem is if you were searching somewhere like e-bay people will put Myford against anything just so it comes up in the results.
                J
                #145848
                Clive Hartland
                  @clivehartland94829
                  I asked Google to find a similar image and it came up with a pr. of trainers, an automatic pistol and a set of 3 models of wargaming figures ?
                  #145854
                  Max Tolerance
                    @maxtolerance69251
                    It looks like part of a Matrix screw pitch measuring machine made by Coventry gauges, though its not complete. It should be mounted on a massive cast base with centres.The screw was mounted between the centres and the indicator placed into the thread. The reading was adjusted until the scale was set to the zero line. The whole unit (which was mounted on balls running in a parallel "V&quot was then advanced using the micrometer causing the stylus to ride up the flank of the thread and back down into the next thread until the scale again read zero and the pitch advance noted from the micrometer dial. This was then repeated until all the threads were measured and any deviation from the correct pitch noted. It was probably made in the 50's or 60's
                    #145855
                    Max Tolerance
                      @maxtolerance69251
                      Having studied the picture again I may be mistaken with the manufacturer. It is a long time since I saw one but it is more likely to be the Pitter gauge unit. It works exactly like the matrix unit but is not quite so sophisticated. The pulley on the back would have had a cord and weight to keep any backlash out of the measuring micrometer.
                      #145860
                      rebekah anderson
                        so all it does is measuring?
                        it doesn't machine anything?
                        #145867
                        DrDave
                          @drdave
                          Ah! So that is what it is. I did wonder what on earth it was when it (or something similar) came up on eBay recently.
