Sensor for toy
Sensor for toy
Home › Forums › General Questions › Sensor for toy
Viewing 25 posts - 1 through 25 (of 30 total)
  • #22930
    OuBallie
      @ouballie
      Morrison’s Halloween toy
      #134583
      OuBallie
        @ouballie
        Some advise sought please.
        Other half bought one of Morrison's Halloween Petrifying Prisoner toys at half price yesterday.
        Unfortunately someone had removed/half inched the small front facing activation sensor, with just two bare wires where it should be.
        Does anyone have any idea what that sensor is and can I get something similar.
        The 'toy' works via the 'Test Me' button.
        I will be in credit if I can get it to work via a sensor.
        Power is by means of three AA batteries, but haven't checked if connected in //le or series.
        Geoff – Ready to machine the drill vice bolts.
        #134585
        Sub Mandrel
          @submandrel
          Hi Geoff,
          What does said prisoner respond to? Light, movement or… if he's cheap and cheerful, it's probably a phototransistor or photodiode.
            Can you measure voltage on wires.
            Perhaps you can see if putting a resistor across the wires makes it work.
            #134601
            OuBallie
              @ouballie
              Neil,
              Cheap and cheerfull it most certainly is, and other half said a bunch of ladies nearly had pups when one of them activated the thing by moving her hand in front of it, and it burst into life with flashing eyes and voice. SHMBO joined in the laughter as well.
              There is a 4mm wide slot in a front facing moulding that houses the sensor.
              I never bothered to inspect them when they where first put on the shelf for sale, so cannot describe the sensor.
              Bazyle,
              Will check the voltage.
              Thank you both for your quick responses.
              Geoff – I WILL have to replace the damaged power feed worm gear in the lathe. Oh effing bother!
              #134604
              Richard Marks
                @richardmarks80868
                Most likely to be an infra red sensor similar to those used in the detectors in outside intruder lights.
                #134608
                nigel jones 5
                  @nigeljones5
                  just take it back and get another???
                  #134620
                  Sub Mandrel
                    @submandrel
                    I think it will be a photo diode and a simple bridge/comparator circuit with two different time constants. Any sudden jump in the voltage across the diode (caused by a shadow) will set off the alarm. it may be more sophisticated with a microprocessor these days, of course, but any circuit like this will be self compensating, so any photodiode wired to be reverse biased should work to some extent (if I'm right!).
                    Grizzly bear
                      @grizzlybear
                      Hi OuBallie,
                      Take the duff one as far as Morrisons car park. Go in store and buy another one. Go to car, swap duff for good, march back into store, have tantrum, then ask for a refund, job done.
                      Bears can stoop pretty low, they have to, to catch them salmon.
                      Regards, Bear..
                      #134664
                      V8Eng
                        @v8eng
                        I'm with fizzy on this one, why not just take it back for a refund or replacement?
                        Edited By V8Eng on 05/11/2013 14:00:42
                        #134682
                        Springbok
                          @springbok
                          take it back not worth the hastle and time to fix it
                          bob
                          #134685
                          OuBallie
                            @ouballie
                            Would if I could, but it was on an end of line 1/2 price sale, and was the last one.
                            It works, but only manually.
                            Still have to check the voltage at those bare wire ends.
                            Geoff – Proof reading/checking BH600G Apron oiling write-up before posting. Yes it's done! Photos up first though.
                            #134688
                            mark costello 1
                              @markcostello1
                              Why not look online for a description and picture of the toy, might find an answer there.
                              #134706
                              Sub Mandrel
                                @submandrel
                                Geoff, if shorting the wires together then separating them sets it off, it's probably a photodiode.
                                OuBallie
                                  @ouballie
                                  Thanks for all the responses.
                                  Petrifying Prisoner
                                  Neil,
                                  Correct diagnosis, that is what happens. The slot looks to be the right size at 4mm.
                                  New photo Album – Missing Sensor
                                  Geoff – Bad night, but I will get into the workshop with luck later, but in carefully does it mode.
                                  Edited By OuBallie on 06/11/2013 09:51:38
                                  Photo insert actually working on the iPad now. Well done whoever sorted this out!
                                  Edited By OuBallie on 06/11/2013 09:54:07
                                  #134764
                                  Springbok
                                    @springbok
                                    bin it
                                    Bob
                                    #134790
                                    Sub Mandrel
                                      @submandrel
                                      It's the petrifying pensioners around here that scare me.
                                      OuBallie
                                        @ouballie
                                        Update.
                                        Have tried three photodiodes:
                                        Two with a dark 'lens' one being IR Filtered but they only work when a bright light is aimed at them
                                        The third has a clear lens that works when light is interrupted.
                                        It appears to need a proximity/movement sensor of some sort.
                                        Ready to file this in the Lost Cause folder and just let her indoors operate it manually, BUT I will be in credit with her if I can get it to work properly
                                        More photos added.
                                        Geoff – A week wasted with nothing done.
                                        #136542
                                        Les Jones 1
                                          @lesjones1
                                          Hi Geoff,
                                          If you have any LDRs (Light dependent resistors.) you could try one of them. They tend to be more sensitive than photo diodes. Maplin no longer seem to stock them so I do not know where you could buy one without sending away for it.
                                          Les.
                                          #136544
                                          Steve Withnell
                                            @stevewithnell34426
                                            Geoff – I have some big LDR's somewhere I acquired from street lamps as a kid, let me dig out what I have in the scrap box and I'll post the resistance readings, see if one of those will do the trick.
                                            Steve
                                            #136566
                                            Steve Withnell
                                              @stevewithnell34426
                                              Only managed to find one – but it is big, around 25mm. it's pretty much open circuit in the dark (>50Mohm) and 500K in bright artificial light. Sounds like the wrong characteristic to me.
                                              Steve
                                              #136639
                                              I.M. OUTAHERE
                                                @i-m-outahere
                                                Hi Geoff,
                                                Just out of curiosity if you hook up the IR filtered PhotoDiode can you get the unit to activate by pointing a TV remote at it and pressing one of the buttons ?
                                                Ian
                                                Edited By SLOTDRILLER on 29/11/2013 03:37:56
                                                #136645
                                                OuBallie
                                                  @ouballie
                                                  Thanks for looking Steve.
                                                  Will give that a try Ian.
                                                  Geoff – Hopefully workshop time today
                                                  #136923
                                                  OuBallie
                                                    @ouballie
                                                    Ian,
                                                    Your suggestion works.
                                                    Does that mean it needs a far more sensitive IR diode? If so, how do you specify it?
                                                    My qualifications are all with HV, with bits and bytes just making an appearance when I left the profession.
                                                    Other half said the ladies where waving their hands in front of the inbuilt sensor to activate it.
                                                    Progress is being made, with thanks to all the help received.
                                                    Geoff – Washing down and hung
                                                    #136944
                                                    I.M. OUTAHERE
                                                      @i-m-outahere
                                                      Hi Geoff,
                                                      Isit possible that there could be an IR LED in parallel to the photo diode ?
                                                      I was thinking that it could just be a simple comparator circuit that senses the voltage of the negative side wire and that negative side wire could have a small resistor in series that along with the current limiting resistor for theIR LED would create a voltage divider and you also get a voltage drop across the LED.
                                                      So by placing the Photo diode in parallel with the IR LED and it's current limiting resistor you have a light activated bypass switch as it creates a short across the led / resistor and this would create a very short voltage spike that a comparator could sense .
                                                      the other resistor would be internal to the sensor circuit in the doll , maybe if you can measure the voltage on the leads and then measure the resistance of the low side ( negative ) lead to the battery negative ?
                                                      I was playing around with a laser training tool that I made a couple of years ago for pistol shooting , it uses a sound activated laser mounted to the gun that activates a Photo transistor in a receiver on the other side of the room .
                                                      I dug the receiver out and set it up and sat my tv remote on top , then pressed a button and if I waved my hand past at about 2 ft away there reflected IR beam off my hand activated the receiver .
                                                      Just a thought.
                                                      Ian
