Low tension coil
Low tension coil
Home Forums I/C Engines Low tension coil
  • #42911
    steamdave
      @steamdave
      Hello all
      Does anyon know a source of low tension coils in the UK?  I need one for an igniter fired hit ‘n’ miss engine. Hemmingway does not stock them.  I would imagine a call to one of the US engine specailists is required, but which one?
      If no source is known, is it possible to use a normal car / bike / lawn mower 6v coil and just use the secondary winding (keeping the primary out of circuit)?
      The Emerald Isle
      #2240
      steamdave
        @steamdave
        #42924
        Ian S C
          @iansc
          I’m not too sure of the circuit used but some of the opperators of hit and miss engines here use fluorescent light ballast coils,maybe worth a try.I’ll see if I can find out more.Yours IAN.S.C.
          #42933
          Johan van Zanten
            @johanvanzanten
            Hello Dave,
            Here in Holland many stationairy engine men use a ballast coil from an old FL armature.  I use it myself on 2 model engines. You need the old fashion coils with iron and wire, not the electronic ones. They need a battery of 12 volts for a strong spark.
             I don’t  think a normal ignition coil will do the job.
            regards,  Johan.
            #42947
            steamdave
              @steamdave
              Thanks Ian and Johan.
              Seems like I need to look for an old fashioned Fluorescent starter!
              The Emerald Isle
              #42949
              Ian S C
                @iansc
                YOUR SPOT ON Johan,I forgot about the electronic system on the newer lighting sets.IAN.S.C
              Home Forums I/C Engines Topics
