Warco 2 point traveling steady – which model??
Home Forums Workshop Tools and Tooling Warco 2 point traveling steady – which model??
  • #355578
    Rik Shaw
      @rikshaw
      I have just been given this steady and told that it came of a WARCO lathe – model unknown. I have compared it to the fixed steady belonging to my BH600G which is 6" (150mm) centre height and it looks a little smaller. My guess is that it fits on a lathe of around 5" centre height or thereabouts.
      Does anyone know which model it is meant to fit?
      Rik
      Edited By Rik Shaw on 27/05/2018 13:29:39
      #18934
      Rik Shaw
        @rikshaw
        #355580
        richardandtracy
          @richardandtracy
          Looks like the one on my WMT 300. Was used on the WMT300/1 and /2. Has a 6" centre height, but as the cross slide was used for milling, it's a bit thicker than normal.
          Richard
          Edited By richardandtracy on 27/05/2018 13:40:56
          #355596
          Rik Shaw
            @rikshaw
            Thanks for that Richard. If you get a minute could you measure the approx distance from the tip of the brassy noses to the centre of the fixing holes for me? I make it about 144mm. Thanks in advance.
            Rik
            #355600
            richardandtracy
              @richardandtracy
              Top one, Min 138, Max 160 ish.
              Hope that fits.
              Richard.
              #355613
              Rik Shaw
                @rikshaw
                Richard – your dims tie up exactly. Thank you for taking the trouble.
                ATB
                Rik
                #355615
                richardandtracy
                  @richardandtracy
                  As the Warco is the combi machine, it'll also fit a Clarke CL500, CL430, Sealey SM27 etc.. But not the Chester Model B where the centre height is bigger.
                  Richard.
