CCGT 060202 or CCGT 060204
Home › Forums › Workshop Tools and Tooling › CCGT 060202 or CCGT 060204
  • #329029
    Brian John
      @brianjohn93961
      What is the difference between CCGT 060202 and CCGT 060204 ? Can either be used for machining brass, bronze, aluminium and silver steel ? Are they the equal in size and shape so that they will fit in the same holder ?
      NOTE : I thought I had asked this question before but I could not find it using the search box.
      Edited By Brian John on 25/11/2017 01:41:51
      #18753
      Brian John
        @brianjohn93961
        What is the difference ?
        #329031
        I.M. OUTAHERE
          @i-m-outahere
          The last two numbers designate the radius 02 = 0.2mm 04 = 0.4 mm .
          Other than that they are the same  and will fit the same holder , i don't see an issue with machining the materials  you listed .
          http://www.mitsubishicarbide.com/en/technical_information/tec_turning_tools/tec_turning_insert/tec_turning_guide/tec_turning_identification
          There are dozens of carbide insert charts on the internet and i know that kyocera and sandvik both have apps you can put on your phone or ipad etc .
          Edited By XD 351 on 25/11/2017 02:15:49
          #329040
            For your small lathe I would go with the 02 as the smaller tip radius will be more suited to the shallow cuts you are limited to taking.
            #329056
            Douglas Johnston
              @douglasjohnston98463
              The 04 tip will be a bit more robust and may last longer, but I also like an 02 tip on my small lathe (Myford Speed 10 ). The small radius also makes it possible to produce nice sharp internal corners.
              Doug
              #329060
              nigel jones 5
                @nigeljones5
                I use the 202 for copper boiler tube and find it 'sharper' than the 204 and less likely to grab. I have broken a few inserts but you have to do something pretty brutal to damage them. I buy the very cheap ones and they perform perfectly on my slow running L5, so much so that I now use nothing else.
