Dressmakers pin edge finder
Home › Forums › Workshop Tools and Tooling › Dressmakers pin edge finder
  • #18724
    Nige
      @nige81730
      #324496
      Nige
        @nige81730
        I have seen mention, a couple of times now, about the use of a dressmakers pin and a bit of plasticene to construct a makeshift edge finder/wiggler. I cant make out how this would work and YouTube has let me down. Can somebody please explain the mechanics, how the plasticene is placed to not lose the pin when the mill or drill is fired up.
        #324497
          You run the machine slowly!
          Your SX2.7 will go down to about 40rpm which will be fine, infact the slower the better as you can more easily see if the pin wobbles than at high speed where it would be a blur
          #324500
          Nige
            @nige81730
            Where/how do you place the plasticene Jason? Do you just stick a blob as close to the centre of the chuck/collet/tool as possible ? I presume we are talking about the dressmakers pins with the round plastic end to them and which end of the pin goes in the plasticene, i'm guessing the sharp end?
            #324503
              Sorry about the picture being sideways but it shows a dressmakers pin more-or-less centred on the bottom of a milling cutter with a blob of modelling clay. If it's not more-or-less vertical and roughly centred before you start, it will fly off when you wind the speed up. Goggles.
              With the cutter spinning fast (>1000rpm) , the brass rod is used to gently nudge the pin into the centre position. Get it right – and it's not difficult – and the pin's point snaps into alignment with the spindle axis. Works like balancing on a bicycle. However, if you stop the mill, the point stays aligned and you can use it, perhaps with a magnifying glass, to align the cutter axis/centre on a centre pop, line, or edge. With care you can get very close. When ready to take the cut, just pull the pin and plasticine off.
              Since I took the photo, someone on the forum told me the edge of a steel rule is better than a rod. It's true.
              Edit.  Jason hit save before I did.  Now I see he recommends 40rpm rather than my 1000rpm.  For what it's worth I find the pin snaps better at high rpm but hey…
              Edited By SillyOldDuffer on 30/10/2017 18:42:18
              #324504
                yes just stick a lump on the end of a collet chuck or stub of metal held in one. Blunt end of the pin goes into the plasticene, point faces work.
                Start the mill running and then nudge the pin until the point runs true either with your finger nail or by pushing with the end of a steel rule, the eye is a good judge of when the pin is true. You can then line it up with a scribed line or punch mark
                #324505
                Nige
                  @nige81730
                  SoD: Thank you for the picture; so it is that simple Brilliant
                  #324506
                  Nige
                    @nige81730
                    JasonB: Thanks for the clarification smiley
                    #324507
                      If you don't fancy the idea of pins flying about the workshop you can buy a wobbler set that has 3 edge finders and a pin in the set. They all have a ball on one end that fits into a socket in the knurled "chuck" and are set in the same way as the sticky pin
                      This is on the lathe so pic is the right way up
                      Edited By JasonB on 30/10/2017 18:46:31
                      #324509
                      Nige
                        @nige81730
                        Thanks Jason. I have drawings for an edge finder set and they are on my list of things to make when I get my new workshop I was just having problems sorting out in my mind how the pin and plasticene method would work
                        #324510
                        alan-lloyd
                          @alan-lloyd
                          They used to be called sticky pins, when I was an apprentice.
                          #324512
                          Watford
                            @watford
                            Using an ordinary dressmaker's pin (no glass ball) with a dob of plasticene (or blue-tac) is a very useful way of locating a centre pop below a drill or centre drill in the drill press.
                            Mould a small lump, about the size of a sugar cube, around the point of the drill and stick the pin in as near vertical as practically possible.
                            Run the drill at the speed you are going to drill, and centre the pin point with the back of a thumb nail whilst it is running. It will centre and stay positioned.
                            Bring the pinpoint down to the centre pop and you are spot-on. Stop drill. Remove plasticene.
                            Keep the 'Sticky Pin' on the side of the drill casing for next time.
                            Usual safety precautions please.
                            Edited By Watford on 30/10/2017 19:27:08
                            #324552
                            duncan webster 1
                              @duncanwebster1
                              Posted by JasonB on 30/10/2017 18:46:09:
                              Trouble with these is they are very long, so you get a sore right arm winding the knee up and downn, and if you have a round column machine you probably lose alignment. I have it on te list to make a very much shorter version, watch this space.
                              #324569
                                That is what a quill is for!
                                #324621
                                duncan webster 1
                                  @duncanwebster1
                                  Only if you want to have the quill stuck right out for most of your machining.
