While tidying up this has surfaced again. It's the lever operated type with a max capacity of 1in.
Problem – I lack the installation instructions can any one help?
For some of the chucks they give dimensions for where the pivot on the end of the lever needs to be located. I've not had much luck finding anything on this model which is the one Myford usually supplied. I need to mount it on a Boxford though so the attachment Myford provided for the lever to operate against wouldn't be of much use. Boxford appear to have used something which is held in place by 2 screws on the lower front face of the headstock so the lever would have been vertical. Other lathes used an attachment fastened to the bed and Burnherd provided sufficient info to determine where the pivot point should be. That is what I ideally need for the 1" max chuck.
