I hate centre drills…………..
Home Forums Workshop Tools and Tooling I hate centre drills…………..
Viewing 25 posts - 1 through 25 (of 47 total)
  • #130925
    Anonymous
      ………..discuss!
      I've just broken another one; that's the second one in as many weeks. Fortunately the broken bits came out easily. It was the last turning operation on my embryo hob for a worm wheel:
      I'd have been right put out if the part had been scrapped. If nothing else it's 30 quids worth of silver steel.
      The centre drills I've been using are a no-name set I bought many years ago, from an ME supplier, although I'm not sure which one. I've just put the whole lot in the bin; best place for them. I'll keep the nice wooden box they came in though. On Monday I'll order a new set from a reputable professional tool supplier.
      I never use centre drills for starting twist drills on anything other than the lathe. When drilling on the mill I either start straight with a four facet twist drill, or use a carbide spot drill.
      Did I say I hate centre drills? angry 2
      #17179
      Anonymous
        #130932
          Dig them out the bin, they are easily reground to start a new life in a boring bar holder or as a one off form tool.
          I don't even use them for starting drills in the lathe now prefering a spot drill, only time they really come out is when I want a hole for a ctr or the cone on a steam fitting or if I need the long reach ones. Does anyone make long reach spotting drills?
          J
          #130935
          Sub Mandrel
            @submandrel
            I made a simple 'long spotter' by turning a cone on the end of a silver steel rod, and grinding away half of it.
            Interesting point Gray. My keyless chuck is hard to tighten up securely, so I just keep a centre drill in it. I hope I haven't been sabotaging them all!
            John Stevenson 1
              @johnstevenson1
              Centre drills are a throw back to early lathe work. All the books like Chapman write about these as rote but seeing as there have been no new books written for centuries all the old rubbish gets regurgitated in any *new* books that come out
              Easier to copy / paste than do home work.
              The original use for a centre drill was two fold, firstly to put the cone shaped hole in to support a centre and secondly to act as a reservoir for white lead paste that was used as a lubricant for the dead centres of the day.
              Now the first reason still applies but seeing as most people today use revolting centres the long pilot is no longer needed, in fact it's a disadvantage as if it breaks the whole tool is scrap and probably the work. A good dodge is to regrind new centres to about half the pilot length, enough to clear the tip of the centre plus a couple of regrinds.
              THEN only use these for placing centre holes in work for use with lathe centres.
              Anything else you use spotting drills, in industry today you virtually never see centre drills as spotting drills have taken over for one simple reason, they are better or industry wouldn't use them.
              However if you do break a centre drill don't throw it away. Usually this is what you get.
              Sooooooooooo.
              Make the perpetrator do the repair.
              Grind the old broken centre drill up as a trepanning tool as in the two pics below.
              Top view.
              Bottom view, not the clearances all ways round.
              Then feed this in round the brokem tip until the broken bit stands proud, then a quick smack leaves it like this.
              Which is now easier to reclaim now it's missing a hardened piece of tool steel
              #130942
              I.M. OUTAHERE
                @i-m-outahere
                Just out of curiosity have you checked to see that your tailstock is on centre ?
                Ian.
                #130943
                Thor 🇳🇴
                  @thor
                  John, that's a very nice way to get the tip of a broken centre drill out of the work.
                  Thor
                  #130944
                  Boiler Bri
                    @boilerbri
                    That's a good idea John. Looks like you have had a few broken ones to come up with that idea. I usually dig or shatter them out with sharp centre punch.
                    #130945
                    Jens Eirik Skogstad 1
                      @jenseirikskogstad1
                      Do undo broken centre drill: Keep centre drill sharp and use cutting fluid depending on which material you are using as a work piece. Take light cut under work. Be sure the tailstock is in center.
                      #130949
                      Sub Mandrel
                        @submandrel
                        Hi John,
                        Your expertise in grinding that little tool suggests you don't follow your own advixce about not using centre drills
                        Seriously though a good tip for the larger sizes, but it's usually BS0 I break
                        I thought the point was that the centre drill also ensured the centre touches the cone and doesn't bottom if it has a sharp tip and the drill making the depression doesn't. Of course a two step spotting drill followed by a smal ordinary drill can avoid this, but it is two steps.
                        There is a third way – I have an old-fashioned hardened 4-sided centre that can be used to true up an off-centre hole hole or sort out one that has gone 'nasty' – either might easily break another centre drill. Not used much, but has proved its worth.
                        colin hawes
                          @colinhawes85982
                          The pilot on a centre drill is there to giv clearance to the sharp point on a lathe centre. If there is no clearance you can't be sure that the job is running in the 60 degree angle. So far as I'm aware spot drills are nearer 90 degrees so also would be iffy as a centre drill. Colin
                          #130957
                          John Stevenson 1
                            @johnstevenson1
                            Neil,
                            I originally posted this on another forum a while ago, in fact the pictures are dated January 09.
                            I looked for one of these trepanning cutters and as usual because I wanted one, couldn't find on so I sorted out, found a centre drill that had seen better days from a tin of old HSS blanks. Then proceeded to break it on purpose just for the photo essay.
                            From what I can remember, because it was a pre-shortened one, which is what I do to all the centre drills, it took some breaking , just because I wanted it to break.
                            #130967
                            Ian S C
                              @iansc
                              The broken bits can be resharpened as little counter bore drills, and mini countersink drills. As well as tools for boring bars, they make quite good tooling for flycutters in the milling machine, I'v used one to make a gear cutter that worked OK for the job on hand. Ian S C
                              #130968
                              John Stevenson 1
                                @johnstevenson1
                                Posted by colin hawes on 29/09/2013 09:50:35:
                                Colin,
                                No one is saying use a spotting drill instaed of a centre drill for running a centre in, what we are saying is save the centre drills for the use they were intended and use spotting drills to start holes be it in the lather or mill.
                                #130969
                                SteveW
                                  @stevew54046
                                  I don't own any spotting drills, but I'm thinking about it! Could you use a spotting drill to drill a final hole accurate enough to tap? I am thinking of 2.5mm about 10 deep.
                                  I know that's not really what they are for but it could save me a bit of time on a repetitive job
                                  SteveW
                                  #130970
                                  John Stevenson 1
                                    @johnstevenson1
                                    Yes, no problems.
                                    #130978
                                      The only problem with that is you will have to back the drill out more to clear the swarf as the flutes are very short.
                                      The other thing the 90deg spotting drills can be used for is to chamfer or even countersink the edge of a hole by drilling until the spot is larger than the intended hole. This saves having to go back after the hole is drilled and either Csk or deburr
                                      They also make handy engraving tools, I used an 1/8" spotting drill to do these grease cups this morning.
                                      Edited By JasonB on 29/09/2013 13:25:42
                                      #130984
                                      NJH
                                        @njh
                                        I always thought a major advantage of the centre drill is in its extra rigidity especially as a starter for small drills ( I' m thinking < 2mm particularly) I have a few which seem to work well for me but I also bought a couple of spotting drills which I agree work in the larger sizes? I guess, in the hobby arena where we have to pay for all our own tools, the temptation is to carry on using drills for too long whereas in a commercial situation they would be replaced. Andrew I do feel your pain though!
                                        Norman
                                        #130988
                                        Rik Shaw
                                          @rikshaw
                                          I had no idea centre drills were old fashioned. I have a box of 50-60 and use them all the time for starting drills and also for forming cones for my lathe centres to run in. I treat them gently and have not busted one for years – fingers crossed. Old fashioned they may be but then – so am I. dont know If you really want "proper" old fashioned think liberty bodices, spats and bay rum !
                                          Rik
                                          #130995
                                          Dougie Swan
                                            @dougieswan43463
                                            Apologies for this if seems a daft question, but what is a spotting drill?
                                            Dougie
                                            #130996
                                              Short drill with either a 90 or 120deg angle and very little "flat spot" that you get where the two cutting edges meet which makes it start where you want it.
                                              I see thay also do a 140deg point so your split point or 4 facet drill wont snatch as it starts and in answer to my own question yes you can get long ones eg 1/4"dia x 6" long
                                              Edited By JasonB on 29/09/2013 19:59:27
                                              #130997
                                              Dougie Swan
                                                @dougieswan43463
                                                Thanks Jason
                                                Where can I come across some of these?
                                                Dougie
                                                #130998
                                                NJH
                                                  @njh
                                                  Oh dear Rik!!
                                                  I don't know about spats but how about cod liver oil and malt , school milk (yuk), Bengers, food parcels from Australia, milk in glass bottles with cardboard tops left by the milkman with his horse & cart, groceries delivered weekly by the grocer's boy who would also take down the next weeks in an exercise book. Lorry chassis, with no bodywork, being driven to the body plant by a driver swathed in coats, scarves, hat and goggles. Radio sets powered by accumulators, eating breakfast in the winter with just one small black "Valor" paraffin stove to heat the freezing room ………….
                                                  Ah the good old days!
                                                  (They seem good in retrospect though and I don't remember feeling at all deprived at the time !)
                                                  Centre drills? -good reliable, traditional tools – Spotting drills? bah humbug!
                                                  Norman
                                                  Edited By NJH on 29/09/2013 20:05:37
                                                  #131000
                                                    I use the HSS Keo ones from J&L/MSC as I like the imperial sizes Page 115 of their virtual cataloge.
                                                    But you can also try Cutwell, Engineering supplies etc
                                                    #131003
                                                    Ian P
                                                      @ianp
                                                      I thought I had posted this method of recovering from a broken off centre drill previously but I cannot find it so took a picture today of one that I reground a few years ago.
                                                      It was a 3/16" diameter slocumb bit that I broke the point off in a stainless steel job. The tip was stuck in a part that I had almost finished machining and the material was not long enough to shorten and start again.
                                                      I cut a deep 'screwdriver like' slot just a fraction wider than the diameter of the drill and just went in again with the modified bit which just removed the metal surrounding the broken tip (which fell out when I withdrew the cutter)
                                                      Basically the same as JS's single point trepaning tool but has the advantage that it is stronger and self centres itself. Another benefit is that the end result is just a slightly deeper centre hole.
                                                      Ian P
                                                      PS, I cut the slot with a 'Dremel' type cutting disk
                                                      Edited By Ian Phillips on 29/09/2013 21:11:26
