Rolling T Rings
Rolling T Rings
Home Forums Manual machine tools Rolling T Rings
  • #11934
    David Costello
      @davidcostello75947
      David Costello
        @davidcostello75947
        Any one know if there is a Rolling machine to roll TEE Rings 5mm thick MS
        280mm OD.suitable for home workshop.
        Edited By David Costello on 17/05/2012 21:01:52
        #91045
          I think you will have to make one yourself Davy or get someone like AngleRing to roll them up for you. I was talking to a guy doing a 9"Little Samson who cut his T section from an RSJ to get the correct internal radius and then had angle ring do the rolling.
          Did you see the post about a month ago on TT about the three 4"BB1s being built there are quite a few photos of a homemade roller there, think I also posted the link here.
          http://www.model-engineer.co.uk/forums/postings.asp?th=67930
          5mm is a bit thick for an 11"wheel or is it that big single on the mole drainer? Can you not weld a ring into a rolled strip like most do on engine wheels. Or another method is to cut a groove into your rim material and when rolled that traps the leg of the Tee. I can post some pictures of this method tomorrow as I don't have the link on my ipad
          J
          Edited By JasonB on 17/05/2012 22:12:40
          #91061
            Have a look at the 4 photos on the top of this page and the last few of the previous for the groove method.
            You could also look at Jon Rex as he does plans & parts for a ring roller, a modified top roller on that would allow tees to be done but not sure if its man enough, it takes enough effort to roll a bit of 5mm flat let alone a tee.
            Did just have a look at the mole drainer and assume its the two big wheels you are doing, I think built up would be best option
            #91128
            David Costello
              @davidcostello75947
              Thank you Jason have just found a local who will do them for £30 each,3mm thick rim 5/16 tee.
              which i thought was a very reasonable price. they are for the moleplough,& yes i did see the mass production in Holland, with a workshop like that you can achieve anything.
