Improvements to the Mini-Lathe Half Nut Mechanism?
Home Forums Manual machine tools Improvements to the Mini-Lathe Half Nut Mechanism?
  • #64339
    Scrim
      @scrim
      Whilst adding a plastic chip guard behind my SC3 mini lathe apron I decided
      to strip and improve the half nut mechanism. In the case my ‘Super C3’
      (SC3) it’s more a case of a ‘half of a nut’ mechanism in fact as only the lower
      half of the usual pair of half-nuts is present because the new leadscrew guard
      doesn’t leave any room for the upper one. It still seems to engage and drive the
      saddle ok, but I found the engaging lever would often stick so I wanted to
      improve it.
      I also noted the usual mini-lathe problem with the dovetails and gibs
      making poor contact so I expected to make some marked improvements by lapping
      them to a better fit.
      However, the more I study the mechanism the more I think the manufacturers
      need to redesign it from scratch. It’s quite a surprise it works at all as far
      as I can tell. Virtually all the dovetail in contact with the half nut is
      missing on one side where a circular recess has been cut for the cam type (?)
      mechanism that the handle turns, and on the other side the gib is held in place
      by two screws+washers. It looks like a total bodge and I suspect any minor
      attempts to improve it may stop it working by what ever mysterious means it
      currently functions. Are there any articles out there about this issue and ways
      to resolve it, because I can’t find anything beyond a mention that the mechanism
      includes a gib?
      Scrim
      #11746
      Scrim
        @scrim
        #64380
        Scrim
          @scrim
          Looks like I might be on my own with this one then!
          Scrim
          #64383
          john swift 1
            @johnswift1
            Hi Scrim ,
            I expect its just the same as the standard C2 and C3 lathes
            so your not alone , but could be the first to find the solution !
            while there is lots of details of mods to the C2/C3 lathes on the web
            a half nut mod isn’t to be found
            the nearest for a C6 lathe can be found here —
            While I’ve made some mods to a Machinemart CL300m lathe
            eg. replace the plastic back gears with metal ones , replace the spindle ball races with taper roller bearings and scrap metal gibs with brass gibs
            the half nut mechanism is some way down the to do list
            Scrim
              @scrim
              Thanks John,
              It’s a good point about the half nut mechanism being well down the to do list! I wouldn’t have bothered looking at it if I hadn’t already been working on the apron. Also, it does seem my mechanism is a little crankier than some as a friend says they don’t get the sticking problem I experienced.
              I’m tempted to just try to get it working as before (not necessarily a trivial exercise!) and get back to the both more important and more easily fixed issues for now.
              Scrim
              #64405
              AES
                @aes
                Scrim,
                QUOTE: I’m tempted to just try to get it working as before UNQUOTE:
                Please don’t do that – what I need (and I suspect many others too) is for you to spend many hours working out a real good mod, then more hours photographing and writing it up, then get David Clark to publish it in MEW. We’ll all benefit that way! (Grin).
                Seriously, on my lathe (mine is actually a “Real Bull”, not a Sieg) I did find it took me quite a time to set that up nicely at the start (after cleaning n degreasing) so that the self act engaged/disengaged positively each time. But so far that seems to be more or less OK still. But I would like a better system for that system though – as you say, it’s well down the list still!
                Where I do have a much bigger problem is with lowering the self act rack on the bed casting and/or adjusting the carriage handwheel to take out the LOADS of backlash I’ve got – I’ve had some success with that but if I want a decent finish I still use the self act only (not the handwheel) ‘cos the handwheel has so much backlash n general “slop” that I just CANNOT get a decent finish using the handwheel – with the carriage adjusted decently (no “slop” to the bed) it’s pretty tight to turn the handwheel and it tends to “jerk” – PERFECT for a good finish!
                So while you’re at it, do a decent mod for that too please (grin again) – and YES, I have seen a mod on one of the US fora re machining up an eccentric bust for the handwheel bearing.
                Krgds
                AES
                #64407
                Scrim
                  @scrim
                  Fear not – if I come up with anything I’ll pass it on one way or another!
                  Scrim
                  #64686
                  Sub Mandrel
                    @submandrel
                    Hard to comment without seeing a photo. The original mini-lathe arrangement is quite good IMHO. It even has an adjuster to set how closely the half-nuts close on the leadscrew – obviously pointless with an ‘half-nut’.
                    Scrim
                      @scrim
                      Thanks folks. For now I’ve made do with the following which has improved
                      things a lot:
                      I fitted a large diameter thin spring washer between the apron and the
                      ‘cam’ type disk that’s rotated by the engaging handle.
                      I cleaned up the face of the handle which bears on the apron by facing in
                      the lathe (with no apron you have to hold the saddle against a bed stop and use
                      the top slide to feed the tool to the left).
                      I replaced the two soft washers which hold the gib in place with
                      two strong steel ‘washers’. I used the ends of the two feeler gauge strips that
                      already had holes bored in them so all I had to do was cut off with a Dremel and
                      clean the edges up.
                      With adjustment of the gib it now has a smooth and precise feeling
                      action.
                      It doesn’t appear that using a single half nut detracts from the
                      mechanisms function, so I won’t worry about that as I like having the guard to
                      keep swarf off the lead screw. ARC actually offered to send me the upper half
                      nut when I bought the Super C3, but I decided not to take them up on it for some
                      reason.
                      Scrim
