The speed controllers fitted are either of American or Chinese origin and appear in two ratings, 6 Amp and 12 Amp.
It is likely that yours is the lower of the two values.
The current overload setting is adjustable but the value of the current sensing resistor may be different from the 500 W motor to the 750 W motor.
There is an adjustment process that requires a current meter to set the correct level of protection.
http://www.kbelectronics.com/manuals/kbic_manual.pdf
Just be careful when making adjustments as the board is 'Live'
