What Did You Do Today 2026
Home Forums The Tea Room What Did You Do Today 2026
Viewing 25 posts - 51 through 75 (of 116 total)
  • #839252
    bernard towers
      @bernardtowers37738
      We call them Rivnuts
      #839257
      Bazyle
        @bazyle
        Classic example where you are undoing 4 screws and the last one the rivnut spins. Invented by the Devil.
        #839376
        Nigel Graham 2
          @nigelgraham2
          “Rivnut” sounds like a particular brand, and might well need special insertion tools..
          The fasteners I had in mind – and have a small collection in reality – are different beasts.
          They are Hank Bushes: nuts with a short, deeply countersunk shank. The shank is pushed through a close-fitting hole in the plate then riveted into a countersink in that. At work we closed them down with a simple dome-ended punch struck with a hammer. A more elegant version could be used in a fly-press or arbor-press.
          The hexagonal ones’ sharp corners and slight undercut, give them a bit more grip in the material than a cylindrical one would. Their shape would also look right in visible places on a model, assuming suitable size.
          This is a Hank Bush, or Hank Rivet Bush; the image from a fastener-supplier’s catalogue. Readily available but likely, now only with ISO-M threads.
          HRBHMCSC025022-0.
          Another form of the many varieties of static-nut fasteners, has a cylindrical body on an elliptical plate with two small holes for rivets. Plus there all those spring-clip nuts and the like for thin sheet-metal work.
          It’s probably worth inserting the screw with a spot of anti-seize grease on its thread, to reduce the risk of the bush rotaing when trying to remove the jammed screw.
          (My steam-wagon chassis, built from 50 X 25 X 5mm HRS channel, has tapped holes wherever possible, and where the lack of a nut would not be noticeable.)
          #839388
          bernard towers
            @bernardtowers37738
            Rivnuts are freely available if googled
            #839452
            Nicholas Farr
              @nicholasfarr14254
              Hi, I took delivery of four of these quick action welding vices today.
              CIMG3509a
              Very handy for setting up and tacking / welding frame-work, or just a right angle bracket or a T-shape piece, The blocks just stop the moving jaw tilting up, in the above photo, but shouldn’t need them on square or rectangular sections
              They will also hold round bar and tube as well, but small round bar / tube would need a block on the moving jaw side, to stop the jaw from tilting up. The blocks in all cases need to be at least the same height as the top of the clamping screw.
              CIMG3510b
              I’ve used these sort in my day jobs, and if you use all four together, you need a decent flat surface to put them on, otherwise any frame you make will probably end up being twisted.
              Regards Nick.
              #839489
              Nicholas Farr
                @nicholasfarr14254
                Hi, the correct way of fitting a rivet bush that Nigel Graham 2 has shown, is shown Rivet bush fixing The serrated type are also done in the same way Rivet bush fixing
                Regards Nick.
                #839494
                Nigel Graham 2
                  @nigelgraham2
                  Bernard –
                  They are – so are hank-bushes. I looked them up for my previous reply.
                  Nick-
                  A press. Yes, I suggested that! We had a flypress available but more often used a hammer and punch. This was for assembling cases for bespoke electronic equipment, so usually aluminium sheet.
                  #839496
                  Nicholas Farr
                    @nicholasfarr14254
                    Hi Nigel, I’ve done them with a suitable sized ball bearing on a press.
                    Regards Nick.
                    #839681
                    Phil P
                      @philp
                      I finished the main steam valve for my model mill engine Agnes.
                      P1060765P1060767P1060770
                      #839683
                      bernard towers
                        @bernardtowers37738
                        Nicely done Phil and nice neat soldering
                        #839695
                        Nigel Graham 2
                          @nigelgraham2
                          Fine work Phil. How did you form the sphere? Form-tool, copying or ball-turning attachment?
                          #839697
                          Phil P
                            @philp
                            I did it with a Hemingway ball turning tool that I made years ago.
                            #839753
                            Nigel Graham 2
                              @nigelgraham2
                              Thankyou – I am impressed with what it offers you.
                              I do know the Hemingway kits, having made a Boring-bar set and a ‘Kennet’ Tool-&-Cutter Grinder, and started a Keyway Slotting Attachment.
                              #839766
                              Dell
                                @dell
                                I received something I had been after for ages a small powered hacksaw.
                                It’s a Kennedy Hexacut 60 originally supplied without motor so no cast base, the motor is a bit weak but starts once helped , no on/off or cutout switch but apart from that it just needs a clean, not sure if I am going to get the current motor serviced or change it or even convert it to 24volt.
                                I will use it as is for now apart from adding a switch as picture until I decide.IMG_0504-compressedIMG_0507-compressedIMG_4743
                                #840407
                                Nicholas Farr
                                  @nicholasfarr14254
                                  Hi, yesterday I had to dig out my old Compaq Deskpro to scan a Advantix film for my daughter, using my CanoScan 2700F, all was going well to start with, but then the desktop decided to restart itself just when the scan was about to sent to a folder, and so it meant reloading the programme, but then I had to do the same thing after every scan. Turns out that the hard drive was running hot, and so, I tried putting it on ice, so to speak. A 180 x 150 x16mm slab of aluminium for the drive to sit on, and another lump about 30mm thick on top, worked out well.
                                  CIMG3511
                                  After I finished my daughter’s one, I decided to do one of my own, and below is a photo of the scanning window.
                                  CIMG3513
                                  I dare say many will know exactly where this photo was taken, which was in September 2001.
                                  Regards Nick.
                                  #840414
                                  Andrew Crow
                                    @andrewcrow91475
                                    Obviously early September.
                                    #840416
                                    Nicholas Farr
                                      @nicholasfarr14254
                                      Hi Andrew, it was in fact the 15th of Sept.
                                      Regards Nick.
                                      #840443
                                      Andrew Crow
                                        @andrewcrow91475
                                        Ah yes, my mistake, should have zoomed in for a better look.
                                        #840570
                                        Roderick Jenkins
                                          @roderickjenkins93242
                                          I’ve been having a go at making some small slideway bellows:
                                          Design:
                                          bellows 1
                                          A practise in paper:
                                          bellows 3
                                          and finally the finished item:
                                          bellows 2
                                          The biggest problem was finding a source for a small amount of suitable plastic.  Stationery supplies seemed to be the best bet.  I found some 12 micron OHP film which is too stiff and A4 document pockets at 3 micron are too flimsy.  However I found some premium A4 pockets which are 9 micron and that seems to be the sweet spot.
                                          Rod
                                          #840576
                                          Macolm
                                            @macolm
                                            Ah – happy memories. I spent a day or two folding various card types to this format before finding I could get 1mm polycarbonate flat sheet to curve through 90 degrees round a smooth guide. Much easier to clean, and this is still working years later.
                                            #840673
                                            larry phelan 1
                                              @larryphelan1
                                              What did I do today ????
                                              Put a pot on the gas, went out to my cave just to check something, came back later to find the pot and contents stuck to each other !
                                              SHMBO was  “Not amused ” !!
                                              #840879
                                              Phil Lingham
                                                @phillingham79132
                                                I’m rebuilding a Honda CB450 classic racer engine for a friend of mine and needed to tidy up the inlet valve pockets that had been machined previously but not very well and were completely different. One had a 0.75mm step near the outside of the circumference, the other didn’t!
                                                I 3D printed a fixture to clamp the piston and align the gudgeon pin.
                                                PXL_20260311_132033463
                                                Then put it in my tilt and swivel vice and clocked it to get the pocket level
                                                PXL_20260311_132534410
                                                Then using my Wollhaupter boring head I machined the step away and just kissed the face.  Happy with that.
                                                PXL_20260311_142815311
                                                #840892
                                                Nigel Graham 2
                                                  @nigelgraham2
                                                  Took advantage of the sunshine to weld the foot and top plates on two lengths of square steel tube to form the stanchions for a horizontal milling-machine’s drive.
                                                  The puzzle to solve was ensuring squareness of plate to tube, to sufficient accuracy.
                                                  Came in for tea and ended up chasing a frog around the dining-room! After the third run of hopping and scrambling its way around a maze of engineering clutter it landed on the flat top of a socket-set box. It sat there, working out its next move, for long enough for me to plonk an empty ice-cream tub over it, slide a card under it, hence carefully carry it to freedom in the garden.
                                                  The mill was originally built for line-shaft drive so I am creating an overhead version using a single-phase motor and 3-step reduction-drive by Vee-belts; the last stage by link-belt due to the form of the machine body. I have two candidate worm-drives and various large gears, but careful consideration and umpteen dividing-sums showed using belts far simpler.
                                                  I might be able to use one of the worm sets for my steam-wagon’s steering gear-box, though.
                                                  #840915
                                                  Andrew Crow
                                                    @andrewcrow91475
                                                    Finally got round to making an eccentric chuck as designed by Bernard Towers, and managed to complete some eccentric bronze bushes for yet another job.
                                                    Thanks for the design Bernard.
                                                    20260312_140108
                                                    #840918
                                                    bernard towers
                                                      @bernardtowers37738
                                                      Really pleased to have been a help
