Warco WM 180
Warco WM 180
Home › Forums › Beginners questions › Warco WM 180
  • #150351
    Mark Salzedo
      @marksalzedo65030
      Hi,
      I would be grateful for some advice. I have a Warco WM180 lathe and was thinking of fitting a vertical slide for milling. Does Warco sell a vertical slide that fits straight onto the cross slide without having to start drilling holes to accommodate the slide? Also, will a backplate need to be machined to take the collet chuck?
      It may be that others have had experience with these issues?
      Many thanks,
      Mark
      Edited By Mark Salzedo on 21/04/2014 10:02:45
      #7121
      Mark Salzedo
        @marksalzedo65030
        Warco WM 180
        #150360
        Bazyle
          @bazyle
          It looks like Andy has been there done that. for teh vertical slide.
          Warco sell an ER25 collet adapter which looks to have the mounting already sorted. However you could also look at end mill holders or a morse taper ER32 collet holder set.
